hello
I've been playing around with alps faders recently, using 32khz pwm to keep them quiet, at slow speed they are not that smooth, very uncertain. i am not sure as to the reason? it might be the fader is a bit warped? or the pwm is distorted ( i have no oscilloscope to check)
The tkd MVH2-6101 are aprox £50 ( from what i have heard) I wonder if they are more smooth and even and better made? the alps i have were aprox £25. i may try other frequencies and higher voltages to give the PWM more bite. my fader is rated at 10v 800ma , i am using 10v as my supply into a h -bridge. As i am using pwm, maybe i can up the volts to 12v? as long as i do not give it 100percent duty cycle. that may help give more bite and power at lower speeds:? shall give it try.
wow, did you get a free sample from tkd?
