Duke64
    41
About Duke64
  • Birthday 05/23/1986
  • Gender
    Male
  • Location
    Germany, Berlin
Duke64's Achievements
MIDIbox Newbie
  1. Gratz to the sammichSID Crew to the True Chip Till Death Award for "Best Hardware" http://truechiptilldeath.com/awards/the-2010-tctd-awards/ :flowers:
  2. The hoover sounds like Bloody Beetroots/Steve Aoki ... cute! (Nice demo too, funny commercial breaks)
  3. :shifty:
  4. Stellt sich die Frage, ob der mehrfache internationale Versand wirklich günstiger ist, als die Summe von einem Paket und jener Zollgebühr.
  5. I try to delay the swap because I'm afraid to damage the SIDs (I think you know why). But after Fellmings post I do the swap (I hope the last time in my life). The louder channel changeover from left to right >> SIDs sound different. Do you belive in crystal balls anymore ? :sorcerer:
  6. I try to delay the swap-action ... But jeah you are right : the problem are the SIDs. Now, I regret to crashed my matched pair of 6581. But hey, this is the old cool shit and this is the reason, we love this things :ahappy: I correct the level inside of my DAW and all fine.
  7. Hey there, It's me again. No panic, it seems to be everything fine. No SID toast action or something else ;) But after some time I recognized, that one channel is a little bit louder than the other : ~1dBfs. It's normal ? I checked the soldering points of the resistors : all ok. My SID types : 8580 R5 - 3988 25 8580 R5 - 3588 25 Maybe the tolerance of the resistors or the different types of SIDs are the problems? If I don't know if it's normal or not, I have no ambitions to solder out the caps or trans and replace then. I have the problem in Stereo and mono mode. I test it with the InitialPatch. ... and, no. I think it's not a user error : I use LineIn channels on my interface, so no preamp differences. I tested 4 pairs of line-in channels, everytime the same problem. AND ... I test another interface. And no, the software/channel-strip is configured right. SO I think it's the sammich. Thanks for your help, again. Greetz, Tom
  8. Die Freigrenze für Geschenke liegt irgendwo bei 45 Ocken. http://www.zoll.de/c0_reise_und_post/b0_postverkehr/f0_geschenksendungen/index.html Die Leute vom Zoll wollten eine Rechnung. Da ich aber keine habe, konnte ich auch keine überreichen. Dafür haben sie einen Ausdruck bekommen, wo vom Absender bestätigt wurde, dass dies ein Kumpelpaket ist und ein wenig was wert ist. Dadurch musste ich einen Betrag unter 10 Euro bezahlen :whistle:
  9. Scheinbar werde ich nicht älter. Wenn jemand immer von seinem Lötkolben redet, habe ich einfach zweideutige Bilder vor Augen. Besonders, wenn es ein Zauberkolben ist :sorcerer: :ahappy:
  10. Liebe Gemeinde, durch meine Unachtsamkeit bezüglich der Brightness, ist der Transistor T1 (BC337) hopps gegangen. Nach dem Ersetzen leuchtet wieder alles froh ... Sogar das urpsürnglich tot geglaubte Display leuchtet wieder in grün. Durch das herum messen an den Header/Dispaly Anschlüssen habe ich die betroffenen Stellen am PIC zerlegt, der PIC an sich arbeitet aber noch. Auch hier wirkte ein Ersatz PIC Wunder. Ich möchte mich noch einmal bei allen für ihre Mühe bedanken - die hübschesten und best riechenden Blumen bekommt allerdings der nILS :flowers: :tongue: So long, alles funzt, sammich fertig ! :rofl:
  11. Hier geht es jetzt drunter und drüber ! Keine Sorge, ich bin genau so entnervt von dem Spaß wie ihr :getlost: 1) Ich habe die Display Pins nicht vertauscht, weil mir vorher ein paar andere Sachen aufgefallen sind ... Nachdem ich am Display gemessen habe (SIDs waren draussen), zeigt das Display auf einmal nur noch die typischen Karos, aber keine Zeichen/Buchstaben von der Firmware. Ich habe die Firmware erneut aufgespielt, kein Erfolg. Was ist da passiert ?! Beim Messen habe ich extra darauf aufgepasst, keine Pins falsch zu berührern, um Fehlschlüsse zu verhindern. 2) Das Display hat zwei +5 und GND Anschlüsse. Bei einem Anschluss (LED Power Supply) kommen aber nur ~3.2V an ... 3) Jetzt habe ich mal die Base PCB durch gemessen (PIC und ICs drin, keine SIDs) +9 und +5V wurde an den vorgeschriebenen Stellen angezeigt ... ABER +12 war am Messgerät nur +11. Ich habe bereits zwei regulierte Netzteile probiert (1000mA) und immer das gleiche. Das Messgerät misst aber richtig, habe es testweise mal direkt ans Netzteil gehalten >> 12V. Langsam wird das alles eine Nummer zu wild ... Ich weiß nicht wo ich anfangen soll :sad: Ganz am Anfang ging doch alles ...bis ich Brightness hoch gezogen habe. - beide Displays zeigen keine Beleuchtung - Display zeigen auf einmal nur noch eine Reihe Karos, keine Firmware Buchstaben mehr - +12V ist an den Teststellen nur +11V - am Display liegen nur 3.2V an, anstatt 5V Immerhin gibt das Teil noch Ton von sich ... Edit : wohnt hier ein Sammich-Kenner in Berlin und möchte sich ein Bierkasten verdienen ? :tongue:
  12. Ich habe das gleiche Display bestellt, welches den Bausätzen beiliegt. Sieht auch 1:1 genau so aus ... Von daher sollte es daran eigentlich nicht liegen *fragen dreinschau*
  13. Das Display kam heute an und ich habe es eben eingebaut. Es gibt wieder keine Beleuchtung ... Backlight Voltage ist auf +12 und ich habe es mit und ohne JR4 probiert. Backlight Poti stand sicherheitshalber auf 2Uhr ... Scheinbar hat es da noch ein anderes Bauteil erwischt. Welche sind die heißen Kandidaten ?
  14. Today the 8580s arrived ... and ... everything works fine :ahappy:
  15. No problem ... I found two SIDs yesterday.
