humboldt
    8
humboldt's Achievements
MIDIbox Newbie
  1. And now after putting the case completely together, I notice the jacks clearly marked as IN and OUT... oh well :blush:
  2. :frantics: Eureka! Yep that was the problem. Luckily I have a stereo to mono 'Y' cable to test it. Simple case of user error, its always the simple things that get me... I guess my sammich is fully operational, it sounds awsome! Thanks so much for the help. I HAZ SAMMICH!
  3. Im using mono cables into my Yamaha MR816 interface. I have 6581 SID's.
  4. So I switched the SID's around and no matter what position my SID is in the same jack remains really quiet. So thankfully at least it appears my SID's are good. Ill post some pics tomorrow when I get a chance. Maybe some of the expert eyes around here will spot something :)
  5. Ill try switching the SID's then, I suspect one of them is shot :( At least it seems like my bank sticks are all good.
  6. So I finished my Sammich and alot of things work. I was able to upload the application. Some formatting of banksticks happened. Uploaded patch presets. All my buttons and knobs work. My main problem is that one of the audio outputs is almost silent. If I really crank up my amp to the max I can hear it, but Im almost suspecting this is bleed from the other audio channel. On the display for the SID's it says "sid 1***", does this mean only one of my sid chips is active? Also I should have five banks right? A, B, C and D seem fine when when I go to E it says "no bankstick". Would IC10 be bank E? When I get a chance Im going to have a good look my my soldering and take some pics to post here. Are there any other preliminary tests I should try?
  7. So I got my kit the other day here in Los Angeles. The build process is going great. Although Ive hit one snag.... my kit came with a 2x6 female header instead of 2x5. Im thinking this isnt a big deal if I cut two of the pins off. Does this sound like a good solution? Did anyone else have this problem?
  8. i sent my email, hopefully Im on the list too :) Now I just need to find a pair of SID chips...
