Hello!
I`m currently working on DIY copy of Pioneer DDJ-T1;
As base for my app i use ain64_din128_dout128_v2c which is
very straightforward and easy to understand by newbie like me
with little or nonexistent programming skills.
Everything is working fine - buttons, pots, encs and leds.
Shift button functionality taken from:
works too for AIN`s and DIN`s, but problem arises with DOUT so called "shifting" i will try to explain.
Original DDJ-T1 (and many other controllers) is 4 deck controllers
with 2 control sets used for all 4 deck control.
Switching of controller focus is done by means of "DECK" buttons.
So when i press DECK button controller shifts all inputs to different MIDI values/channels whatever and allso
it switches all leds to display status af that other deck.
And whats interesting that that`s done without Traktor sending any MIDI out to update DOUT`s to reflect other deck LED`s.
For example if deck A has LED1 active and deck B has LED2 active then switching between deck`s would cause LED1 go off and
LED2 go on and vice versa.
Is there any directions or code example that will provide this functionality?
I hope someone will understand my taught and came up with ideas.
