xixi Posted February 18, 2008 Posted February 18, 2008 USB PIC MODULE (18F4550) J2 =====>>>Connection Core Module J11I open MIDI-OX or MIOSStudio ,Might find USB Audio Device ,Now on MIDI-OX or MIOSStudio transmits the data, MIDIBOX64 may receive.midibox64 presses down the button or the potentiometer ,Cannot receive in MIDI-OX or MIOSStudio .I have LTC Module on PCB,Saw to LED when the data transfer will flash ,Other LED was not bright .If from the RS232 connection, can be normal Ask where isn't right?
dj3nk Posted February 18, 2008 Posted February 18, 2008 Hicould you please explain this again ? sry but i dont understand this
xixi Posted February 19, 2008 Author Posted February 19, 2008 My English expression is not good .I have good midibox64, uses LTC the module ,the use is very good.Now I increased USB PIC Module(PIC18F4550),connects above Core Module J11,the work is not normal.The midibox64 transmission data, PC cannot receive the data.I already took down MX232.Is what question ??
SLP Posted February 19, 2008 Posted February 19, 2008 As far as I know, the USB_PIC_Module has many bugs (=does not work good).Why don't you buy a USB-MIDI-Interface?They cost only ~20€Where are you from? (Country?)
