USB PIC MODULE  (18F4550)  J2  =====>>>Connection Core Module J11
I open MIDI-OX or MIOSStudio ,Might find USB Audio Device ,Now on MIDI-OX or MIOSStudio transmits the data, MIDIBOX64 may receive.
midibox64 presses down the button or the potentiometer ,Cannot receive in MIDI-OX or MIOSStudio .
I have LTC Module on PCB,Saw to LED when the data transfer will flash ,Other LED was not bright .
If from the RS232 connection, can be normal
Ask where isn't right?
My English expression is not good .
I have good midibox64, uses LTC the module ,the use is very good.
Now I increased USB PIC Module(PIC18F4550),connects above Core Module J11,the work is not normal.
The midibox64 transmission data, PC cannot receive the data.
I already took down MX232.
Is what question ??
As far as I know, the USB_PIC_Module has many bugs (=does not work good).
Why don't you buy a USB-MIDI-Interface?
They cost only ~20€
Where are you from? (Country?)
