fetching 5mm red-blue diffused leds
cimo
.. i am standing with the SparkFun buttons boards here in front of me feeling so stupid..  :-\ .. when i designed them i hadn t got the bicolor leds, later i got them and discovered that they were common anode, no problemo: a little change in the code and they ll be ok but.... in my board the leds share the common pin with the buttons (supposed to be GND) so i can t really have those leds in my boards, and they are already soldered.. :'( :'( :'(
it hasn t been so easy to find bicolor, red and blue, leds for a fair price, and impossible to find them common cathode.
Does anybody have a source for them? (Jimp where did you get yours?)
looking for 5mm leds bicolor (red-blue) common cathode possibly diffused
(or maybe can i also invert the buttons behavior?)
simone
i don't know about jimp, but i got mine at a surplus house near me
and they are "normal" red and green
inverting the buttons is not trivial.  for one thing, you would have
to use pull-down resistors instead of pull-ups
ie connected from pin to gnd instead of from pin to vdd
have you considered using two 3mm leds?
if i have to make new pcbs i can just route the common anode to a single line aside from the buttons. doh!
i think i will cut the traces on the pcb and hardwire the common anodes, so i can use this pcb atm
i didn t etch the second board yet so i can redraw it with different signal for common anodes and for common pin of the buttons
.. yep i ll do that
simone
