pilo Posted June 2, 2003 Posted June 2, 2003 I(ve got a CNY-17, wich I use in an old midi board power by a 8032, is it possible to use this with the core module (this is the not the same pinout, but I saw how to modify it...).
TK. Posted June 3, 2003 Posted June 3, 2003 Hi Pilo,yes, you can use this optocoupler, it works perfectly with most MIDI interfaces, but sometimes you've to tweak the resistor values, therefore the 6N138 should be prefered.However, here the schematic:Best Regards, Thorsten.
pilo Posted June 3, 2003 Author Posted June 3, 2003 yes, it's exactly the same schémtic as on my board!And I see that i've just to change R6 value to 1.8k, and plug the CNY in the same way as the 6N138... huumm sound great! :)
