I sort of found some info on this here, but it was a dead link, anyone have this backed up?
http://www.midibox.org/forum/index.php?topic=387.0
Otherwise, here's my problem:
I have 2 external serial ports on the c64 case: 2 extenal banksticks in serial1, and serial2.
I have the potential for 8 bankstick eeproms internal...
How to get the external ones hooked up?
I have 2 ideas:
-1- add a 3way switch to switch between serial1, serial2, and one of the internal banksticks.
pros: i have full internal storage (8 eeproms), and I can use either of the 2 external serial ports.
cons: I have to flick a switch depending on which location I want to write to, complex perhaps...
-2- remove 2 internal eeproms (for 6 total internal), address each of the external ones differently,
pros: they all work in harmony...  both external serial ports can be plugged in at once.
cons: I have less internal storage...  and one of my banksticks would be at a "non standard address" - Consequence of this is that I couldn't expect to plug this nonstandardly addressed bankstick into a friends mbSID... (since its address may conflict with one of theirs)
Questions:
1.) Am I making this more difficult than it is?
2.) which option would you recommend above?
3.) do I really need 8 internal, is 6 enough?
3b.) (but having 2 differently addressed external sticks sounds like a bad idea too, in terms of "standards" would you agree?)
4.) If I were to do switching, how would you wire it?  I was thinking of trying to wire just the +voltage for each chip, basically powering up only the chip I want to be active...
Probably....
Externally swappable BankSticks are (were) most useful when the MB-SID app could only use one BankStick.
Now that it can use 8, it's only really useful if you need more than 7 banks of 128 patches at any one time (you can always store patches via SysEx dumps or a patch librarian). It's 7 because one BankStick is used for Ensembles.
I'd probably use 8 internal BankSticks and use the serial ports on the side as an "expansion port"  ;D Maybe some analog inputs, or analog outputs...
Or... I'd wire all 8 pins of the 24LC512 to 8 of the pins of the connector, so the BankStick didn't have a fixed address. Then wire the two ports as the 6th and 7th banks. You could set pins of the socket to ground/+5V to give the chip  power and an ID, and then connect the two IIC wires to both sockets from the master Core.
The 8th one is used exclusively for Ensembles, so that one should be internal. Ensembles with someone else. So... 5 internal, 2 external plus 1 for Ensembles is MORE than enough.
hmm.  mostly, I just wanted to support the concept of bankstick,
I thought it really cute to use the serial ports as oldschool "usb memory sticks"
and since i had the 2 ports just sitting there, i thought why not... :)
Also, I can always repurpose the serial port to some external device, if I ever find the need.
maybe i'll do 1 external bankstick with a switch between serial1/2 ports, so both chips can have the same address, so 6 internal 1 ensemble, 1 external...    or, i can rely on the user (me) to be careful, and only insert one at a time... hahah!
thanks for the ideas, I'll chew on that for a while before i go drilling the case for toggle switches. :)
