Hallo,
wenn ich den SID ansmache kommen in midiox im Midi in und out Monitor dieselben Zeilen:
TIMESTAMP IN PORT STATUS DATA1 DATA2 CHAN NOTE EVENT
000147D6  1  1    F0  Buffer:    8 Bytes  System Exclusive
SYSX: F0 00 00 7E 40 00 01 F7
00014F45  1  1    C0    00    --    1  ---  PC: Acc. Grand Piano
00014F46  1  1    C0    00    --    1  ---  PC: Acc. Grand Piano
00015ADA  1  1    F0  Buffer:    11 Bytes  System Exclusive
SYSX: F0 00 00 7E 46 01 0D 00 00 00 F7
00015AE2  1  1    F0  Buffer:    11 Bytes  System Exclusive
SYSX: F0 00 00 7E 46 01 0D 01 00 00 F7
00015AEA  1  1    F0  Buffer:    11 Bytes  System Exclusive
SYSX: F0 00 00 7E 46 01 0D 02 00 00 F7
00015AF7  1  1    F0  Buffer:  256 Bytes  System Exclusive
SYSX: F0 00 00 7E 46 01 02 00 54 65 63 68 6E 6F 20 35 74 68
SYSX: 20 20 20 20 20 20 7F 00 00 00 00 00 00 00 00 01 40 00
SYSX: 00 00 00 00 40 40 02 00 04 40 00 00 00 43 36 00 00 01
SYSX: 00 00 43 40 02 00 02 40 00 00 00 44 37 00 00 02 00 00
SYSX: 47 40 02 00 04 40 00 00 00 45 34 00 00 04 00 00 00 00
SYSX: 7F 00 00 7F 00 00 7F 00 20 10 2E 00 00 00 07 26 25 07
SYSX: 24 5A 07 24 64 01 40 00 01 50 7F 01 60 00 7F 40 40 40
SYSX: 40 00 60 60 20 40 00 00 00 00 00 00 00 00 00 00 00 00
SYSX: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SYSX: 00 00 00 00
00015AF7  1  1    F7  Buffer:    10 Bytes  SysEx End
SYSX: 00 00 00 00 00 00 00 00 4E F7
00015B5E  1  1    F0  Buffer:    11 Bytes  System Exclusive
SYSX: F0 00 00 7E 46 02 0D 00 00 00 F7
00015B67  1  1    F0  Buffer:    11 Bytes  System Exclusive
SYSX: F0 00 00 7E 46 02 0D 01 00 00 F7
00015B71  1  1    F0  Buffer:    11 Bytes  System Exclusive
SYSX: F0 00 00 7E 46 02 0D 02 00 00 F7
00015B7C  1  1    F0  Buffer:  256 Bytes  System Exclusive
SYSX: F0 00 00 7E 46 02 02 00 54 65 63 68 6E 6F 20 35 74 68
SYSX: 00 00 00 00
00015B7C  1  1    F7  Buffer:    10 Bytes  SysEx End
00015BE5  1  1    F0  Buffer:    11 Bytes  System Exclusive
SYSX: F0 00 00 7E 46 03 0D 00 00 00 F7
00015BEE  1  1    F0  Buffer:    11 Bytes  System Exclusive
SYSX: F0 00 00 7E 46 03 0D 01 00 00 F7
00015BF7  1  1    F0  Buffer:    11 Bytes  System Exclusive
SYSX: F0 00 00 7E 46 03 0D 02 00 00 F7
00015C01  1  1    F0  Buffer:  256 Bytes  System Exclusive
SYSX: F0 00 00 7E 46 03 02 00 54 65 63 68 6E 6F 20 35 74 68
SYSX: 00 00 00 00
00015C01  1  1    F7  Buffer:    10 Bytes  SysEx End
Danach funktioniert zwar alles ich kann sämtliche Parameter verändern aber ich kann die controllerdaten nicht auf dem Midi Monitor sehen, es wird nichts gesendet. Woran kann das liegen ?
Danke für eure Hilfe :) (bei meinen blöden Fragen)
Hallo,
bei der MBSID V1 ist es normal, dass am Anfang SysEx Dumps and die Slaves gesendet werden - damit muss man leben. ;)
Controller senden: ist die CC Funktion aktiviert? Dafuer gibt es eine eigene Taste (und LED)
Gruss, Thorsten.
Nein, die CC Funktion war nicht aktiviert, bzw, die Taster Link, Edit und CC  zwar in die Frontblende eingebaut aber noch nicht angeschlossen weil ich dachte die sind erstmal nicht so wichtig...
Oh mann ...  Aber cool, hihi, jetzt geht alles !!!!
Vielen Dank!!
