I'm using a KS0107/KS0108 compatible GLCD with success. I use the following functions:
  • MIOS_LCD_Clear();
  • MIOS_GLCD_GCursorSet(...,...);
  • MIOS_LCD_PrintCString("...");
    But now, I want to define new characters (with custom sizes). I've fund the following functions:
    • MIOS_GLCD_FontInit();
    • MIOS_LCD_PrintChar();
      I've copied the "
    ..\MIOS 1.9\source code\src\mios_glcd_font.xpm" into a subdirectory of my project. I haven't modified anything in this file and executed the "perl convpix.pl -c mios_glcd_font.xpm" script. Then I've modified the "mios_glcd_font.h" file in order to have the same structure as the original one:
    statis code char * charset = {...,..., ... ,...};
    In "main.c", I've included the .h file and written MIOS_GLCD_FontInit(charset);
    Then: MIOS_LCD_PrintChar(0x00); -> it prints a complete 6-pixel column with random pixels. Why?
    I haven't fund many informations, examples nor tutorials about GLCD.  :-\
    Any help is welcome.
    Thanks!
    nsunier
Yes - since some days there are also C usage examples for GLCDs! :)
Unfortunately they are based on the new project structure, which isn't documented yet. Basically, you would use a "MIOS base" package, which includes the drivers, include files, and even some graphical fonts - and your application itself would only contain a small set of files anymore.
So, here is the C example: http://svnmios.midibox.org/trunk/apps/examples/lcd7/ks0108/c/
And here the graphic font package: http://svnmios.midibox.org/trunk/modules/glcd_font/
You won't be able to compile the code with the old approach that is currently documented on my website.
Therefore I created a temporal package for you, which should give you a good starting point (instead of the global "mios base" structure, it uses a local file structure)
-> http://www.ucapps.de/tmp/ks0108_c_example.zip
In addition, you need to install the "posix_bin" directory as described here
I've included all subfolders of "ks0108_c_example.zip" in my project and included the "glcd_font.h" header. When I do a make, I get this error message:
error: missing definition for symbol "_GLCD_FONT_KNOB_ICONS", required by "_output\main.o"
error: missing definition for symbol "_GLCD_FONT_BIG", required by "_output\main.o"
ERROR!
Any idea?
Best regards,
nsunier
Makefile generated.
Makefile.bat generated.
Assembling MIOS SDCC wrapper
Compiling pic18f452.c
Processor: 18F452
Compiling main.c
Processor: 18F452
Linking project
ERROR!
Ok, you tried to build the application based on the old approach, but this doesn't work anymore as stated above.
The make.bat file, the makefile generator + all the other tools which were used in older projects are obsolete - just start with the project setup in http://www.ucapps.de/tmp/ks0108_c_example.zip
I've tried first to compile only "ks0108_c_example". An error message told me that "MIOS_BIN_PATH" variable was not set. So I create it in User Variables. The error message disappeared and I got this output message:
rm -rf _output/*
rm -rf _output
rm -rf *.cod *.map *.lst
rm -rf *.hex
mkdir -p _output
sh ./bin/mios-sdcc -c -mpic16 -p18f452 --fommit-frame-pointer --optimize-goto --optimize-cmp --disab
le-warning 85 --obanksel=2 -pleave-reset-vector  -I./src -I ./include/c -I ./modules/glcd_font -DDEB
UG_MODE=0  modules/libdev/pic18f452.c -o _output/pic18f452.o
Processor: 18f452
./bin/mios-gpasm modifies _output/pic18f452.asm, result in _output/pic18f452__mios-gpasm-tmp.asm
sh ./bin/mios-gpasm -c -p p18f452 -I./src -I ./include/asm -I ./modules/app_lcd/ks0108 -I ./modules/
glcd_font -DDEBUG_MODE=0  -DSTACK_HEAD=0x37f -DSTACK_IRQ_HEAD=0x33f -I ./modules/mios_wrapper module
s/mios_wrapper/mios_wrapper.asm  -o _output/mios_wrapper.o
glcd_font -DDEBUG_MODE=0  modules/app_lcd/ks0108/app_lcd.asm -o _output/app_lcd.o
UG_MODE=0  main.c -o _output/main.o
Processor: 18f452
./bin/mios-gpasm modifies _output/main.asm, result in _output/main__mios-gpasm-tmp.asm
glcd_font -DDEBUG_MODE=0  modules/glcd_font/glcd_font_big.asm -o _output/glcd_font_big.o
glcd_font -DDEBUG_MODE=0  modules/glcd_font/glcd_font_knob_icons.asm -o _output/glcd_font_knob_icon
s.o
gplink -s ./etc/lkr/p18f452.lkr -m -o project.hex _output/pic18f452.o _output/mios_wrapper.o _output
/app_lcd.o _output/main.o _output/glcd_font_big.o _output/glcd_font_knob_icons.o
Do you think it's OK? Can I integrate my code?
Best regards,
nsunier
That's very strange... You can clearly see in makefile. where that variable is set.
MIOS_PATH = .
MIOS_BIN_PATH = ./bin
include Makefile.orig
Just to be sure I wasn't being code smart and real world dumb, I tried it... And was reminded of all the 231 errors which I didn't notice in your build - they're cosmetic (ugly but not a problem) but they should be there... I think...
C:\Temp\ks0108_c_example\ks0108_c_example>make
rm -rf _output/*
rm -rf _output
rm -rf *.hex
mkdir -p _output
sh ./bin/mios-sdcc -c -mpic16 -p18f452 --fommit-frame-pointer --optimize-goto --optimize-cmp --disable-warning 85 --obanksel=2 -pleave-reset-vector  -I./src -I ./include/c -I ./modules/glcd_font -DDEBUG_MODE=0  modules/libdev/pic18f452.c -o
 _output/pic18f452.o
_output/pic18f452__mios-gpasm-tmp.asm:164:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:167:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:170:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:173:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:176:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:182:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:185:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:188:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:191:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:194:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:200:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:203:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:206:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:209:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:212:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:218:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:221:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:224:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:227:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:230:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:233:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:239:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:248:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:251:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:260:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:268:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:273:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:281:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:284:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:289:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:292:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:295:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:300:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:305:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:310:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:313:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:316:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:319:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:325:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:330:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:356:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:359:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:362:Warning [231] No memory has been reserved by this instruction.
_output/pic18f452__mios-gpasm-tmp.asm:374:Warning [231] No memory has been reserved by this instruction.
sh ./bin/mios-gpasm -c -p p18f452 -I./src -I ./include/asm -I ./modules/app_lcd/ks0108 -I ./modules/glcd_font -DDEBUG_MODE=0  -DSTACK_HEAD=0x37f -DSTACK_IRQ_HEAD=0x33f -I ./modules/mios_wrapper modules/mios_wrapper/mios_wrapper.asm  -o _out
put/mios_wrapper.o
sh ./bin/mios-gpasm -c -p p18f452 -I./src -I ./include/asm -I ./modules/app_lcd/ks0108 -I ./modules/glcd_font -DDEBUG_MODE=0   modules/app_lcd/ks0108/app_lcd.asm -o _output/app_lcd.o
sh ./bin/mios-sdcc -c -mpic16 -p18f452 --fommit-frame-pointer --optimize-goto --optimize-cmp --disable-warning 85 --obanksel=2 -pleave-reset-vector  -I./src -I ./include/c -I ./modules/glcd_font -DDEBUG_MODE=0  main.c -o _output/main.o
sh ./bin/mios-gpasm -c -p p18f452 -I./src -I ./include/asm -I ./modules/app_lcd/ks0108 -I ./modules/glcd_font -DDEBUG_MODE=0   modules/glcd_font/glcd_font_big.asm -o _output/glcd_font_big.o
sh ./bin/mios-gpasm -c -p p18f452 -I./src -I ./include/asm -I ./modules/app_lcd/ks0108 -I ./modules/glcd_font -DDEBUG_MODE=0   modules/glcd_font/glcd_font_knob_icons.asm -o _output/glcd_font_knob_icons.o
gplink -s ./etc/lkr/p18f452.lkr -m -o project.hex _output/pic18f452.o _output/mios_wrapper.o _output/app_lcd.o _output/main.o _output/glcd_font_big.o _output/glcd_font_knob_icons.o
Anyway you'll notice that when it works, there are no errors (OK let's ignore the 231 warnings) - So yours is good :)
  • 3 weeks later...
I'm currently testing the GLCD functions.
It works quite well for the GLCD_FONT, GLCD_FONT_BIG, GLCD_FONT_KNOB_ICONS fonts.
But I'm not able to use the GLCD_FONT_SMALL, GLCD_FONT_METER_ICONS_H and GLCD_FONT_METER_ICONS_V ones?! I got this error message when I do a make:
rm -rf _output/*
rm -rf _output
rm -rf *.hex
mkdir -p _output
Processor: 18f452
Processor: 18f452
s.o
error: missing definition for symbol "_GLCD_FONT_METER_ICONS_V", required by "_output/main.o"
make: *** [project.hex] Error 1
These fonts are defined in the ...\modules\glcd_font\glcd_font.h:
// $Id: glcd_font.h 69 2008-02-01 00:20:18Z tk $
 * Header File for GLCD Fonts
#ifndef _GLCD_FONT_H
#define _GLCD_FONT_H
// Defines array pointers to all available fonts
// (hope that SDCC ignores predefined constants which are not
// compiled into the project)
// Pointers are defined as 4-byte arrays. Actually, this is only the font
// header, the bitmap data follows after the header, but is not counted
// here (not required)
extern code char GLCD_FONT_BIG[4];
extern code char GLCD_FONT_SMALL[4];
extern code char GLCD_FONT_KNOB_ICONS[4];
extern code char GLCD_FONT_METER_ICONS_H[4];
extern code char GLCD_FONT_METER_ICONS_V[4];
#endif /* _GLCD_FONT_H */
What should I modify?
Best regards,
nsunier
In this new structure, I can't find main.h
I was using it to define these parameters
// Global definitions
#define AIN_NUMBER_INPUTS     53    // number of used analog inputs (0..64)
#define AIN_MUXED_MODE         1    // set this to 1 if AIN modules are used
#define AIN_DEADBAND           7    // define deadband here (higher values reduce the effective resolution but reduce jitter)
                                    // 7 is ideal for value range 0..127 (CC events)
#define NUMBER_OF_SRIO        12    // how many shift registers chained at the DIN/DOUT port (min 1, max 16)
#define DIN_DEBOUNCE_VALUE    10    // 0..255
#define DIN_TS_SENSITIVITY     0    // optional touch sensor sensitivity: 0..255
and
// Global Types
// status of analog toolbox application
typedef union {
  struct {
    unsigned ALL:8;
  struct {
    unsigned DISPLAY_UPDATE_REQ:1;  // requests a display update
} app_flags_t;
// Export global variables
extern app_flags_t app_flags;
#endif /* _MAIN_H */
How can I do the same thing in the new structure?
Read the readme.txt in the module directory ;)
You can do your defines and declarations in any file wherever it'll work. You can create main.h and include it if you want, just like before.
Oups! Sorry I read too quicky this readme file. Now it works!
But there is still a question about this readme. There is written "1) Makefile: add "glcd_font_big.o" to OBJS variable". What are .o files?
Thank you very much for your help! :)
.o files are object files, they are the output that GPASM creates. GPLink straps them all together and makes your hex file.
With MIOS/GPUtils, we just specify the .o filename, and it will be created from the .c file by the same name.
Enjoy :)
