4 Posted April 5, 2008 Posted April 5, 2008 Hi.I have been inspired by ucapps to use SID in my home-made keyboard project.However, I am that kind of person, that tries to build it's own design. I have obtained the MOS 6581 datasheet but I am facing with some problems playing sounds. There are some pops sometimes and also strange problems with only voice2 working (tests on C64 shows that SID is in perfect condition).I have two main questions:1. Is this SID driver sequence OK: note on: attack/decay=0, sustain/release=0, voice&gate=0, frequency set, attack/decay set, sustain/release set, voice set with gate=1;note off: just gate=0 (voice shape remains untached)2. In wich file is the program code with communication between PIC and SID that is used in midibox projects? I would like to compare it with my code. I am using CCS C-compiler and 16f877a.Thank you for your responce.
TK. Posted April 6, 2008 Posted April 6, 2008 Hi,the MBSID code is located here, and the SID transfer routine in sid_sr.inc, but I guess that it won't really help you. The synth engine which handles the gate is interrupt driven (-> sid_se*.inc), and very complexDid you already solve the issue? If not, I can give you some more explicite hints.The "Pops" could be related to the ADSR bug, which require you to handle the gate very carefully (more infos if still required), and the non-working voices could be related to an erroronous filter assignment configurationBest Regards, Thorsten.
4 Posted April 27, 2008 Author Posted April 27, 2008 Thank you for your reply.I haven't solved the problem because I have put off it for a while :) I am finishing the midi controller part at the moment (It uses Crumar Performer keyboard, touch pads from broken laptop computers and a touchscreen)However, I would be glad if you would give me some additional hints about the gate triggering. I have looked at the code you linked but it is complicated indeed. If it will be necesary to go trough it, I will take a chance.Regards, Ziga.
TK. Posted April 27, 2008 Posted April 27, 2008 Additional hints: between clearing all ADSR registers and setting new values, you should wait at least for 20 mS to ensure, that the envelope generator has reached the lowest level, before setting the gate again. If you re-configure the ADSR earlier, the next envelope could fail (related to ADSR bug -> "hick ups")Since you are at a very early programming phase, I propose you to use a static ADSR setting "00F0". Attack, Decay, Sustain are set to 0 - with this configuration, you won't notice effects related to the ADSR bug -> better for debuggingOnce the voices can be triggered properly, you should setup an interrupt driven timer which takes care about proper gate/ADSR control. Best Regards, Thorsten.
