my first go at a mod in MB SID.. i wanted to be able to start a seq in the bass or drum engine without having to trigger a note on..
after following this topic.
http://www.midibox.org/forum/index.php/topic,11188.0.html
i had a go at this.
cs_menu_tables.inc
CS_MENU_TABLES_B
	;;              pointer to table      par. button pressed      exec button pressed   page name          var            max  print function
	CS_MENU_T_ENTRY	CS_MENU_TABLE_B_ROOT, CS_MENU_Page_Root,       CS_MENU_BUTTON_Play,   "---", SID_PATCH,               0x7f, PRINT_PAT  ; (special handling in CS_MENU_PageUpDown selected with SID_PATCH)
and:
CS_MENU_TABLES_D
	CS_MENU_T_ENTRY	CS_MENU_TABLE_D_ROOT, CS_MENU_Page_Root,       CS_MENU_BUTTON_Play,   "---", SID_PATCH,             0x7f, PRINT_PAT  ; (special handling in CS_MENU_PageUpDown selected with SID_PATCH)
it works out quite nice.. in a bassline or drum patch, once in the menu root, menu button will toggle start /stop sequence  8) cool to be able to just hold the little box and trigger / tweak patterns..  [[sUPER FUN!!!]]  ;D
switching to a lead patch gets your main menu back..    now i just need to replace my wobbbbly encoder switch!
..just thought id share that.
yes it work this way but how you come back to main?  ;)
CS_MENU_BUTTON_Sel5
	;; if in main page (CS_MENU[7]), goto to PlayNote/StartSeq
	movlw	0x00
	GOTO_IFSET CS_MENU, 7, ACCESS, CS_MENU_MS_PlayNote
	;; select button #5, set cursor to 5th position
	clrw
	movlw	0x04
	rgoto	CS_MENU_BUTTON_Select_Cont
this is mine.
i move just 0x00 into W because i've just a stereo sid and CS_MENU_MS_PlayNote read the current SID selected in W. for slaves code must improved like CS_MENU_BUTTON_Play show. reading the sid state in CS_MENU_SELECTED_SID_FLAGS (set by CS_MENU_BUTTON_SID[1234]) and move the right SID number 0x0[0123] into W.
by changing to another patch.. i only have the play button mod on bass & drum engine..
probably a lazy way to do it, but it seems to work out for me.  ;)
CS_MENU_BUTTON_Sel5
	movlw	0x00
	clrw
	movlw	0x04
this is mine.
due to some change in the rc19 this mod need some more tweak.
the function CS_MENU_BUTTON_Select_Cont now call like shown here the new CS_MENU_SHIFT_Button that you can find in cs_menu_shift.inc
	;; branch if in SHIFT page
	GOTO_IFSET CS_STAT3, CS_STAT3_SHIFT_PAGE, ACCESS, CS_MENU_SHIFT_Button
because of this, if you have a minimal CS (like me) with Menu button as Shift (that is a mod and not come with the original code) this call make conflict when you hold the Menu button to show the Shift page, and push the select button that have play function too, and because CS_MENU, 7 is not cleared by the Menu Button when you call shift. So i suggest to modify functions like here:
CS_MENU_BUTTON_Exec_NoStartup
	;; activate/deactivate menu button function
	bcf	CS_MENU_MODE, CS_MENU_MODE_MENU_PRESSED
	btfss	MIOS_PARAMETER2, 0; if button is pressed
	bsf	CS_MENU_MODE, CS_MENU_MODE_MENU_PRESSED
	;; if in main page (CS_MENU[7]), goto shift function <=
	GOTO_IFSET CS_MENU, 7, ACCESS, CS_MENU_BUTTON_Shift <=
	;; do nothing if button has been depressed
	btfsc	MIOS_PARAMETER2, 0
	return
	;; EXTRA for Exec/Menu button:
	;; exit SID player mode if CS is disabled
	GOTO_IFSET SID_STAT, SID_STAT_SIDPLAYER_CS_DISABLE, ACCESS, SIDPLAY_Disable
	goto	CS_MENU_Exec
CS_MENU_BUTTON_Sel2
	;; if in main page (CS_MENU[7]), call PlayNote/StartSeq <=
	GOTO_IFSET CS_MENU, 7, ACCESS, CS_MENU_BUTTON_Play <=
	;; select button #2, set cursor to 2nd position
	clrw
	movlw	0x01
	;; exit with message if SID player mode enabled and SID1 selected
	BRA_IFSET SID_STAT, SID_STAT_SIDPLAYER_CS_DISABLE, ACCESS, CS_MENU_BUTTON_SP_IgnoreMsg
	bcf	CS_MENU, 7 <=
	btfsc	MIOS_PARAMETER2, 0; if button has been depressed <=
	bsf	CS_MENU, 7 <=
	;; activate/deactivate shift function
	bcf	CS_MENU_MODE, CS_MENU_MODE_SHIFT_PRESSED
	bsf	CS_MENU_MODE, CS_MENU_MODE_SHIFT_PRESSED
	;; change to SHIFT page
	bcf	CS_STAT3, CS_STAT3_SHIFT_PAGE
	bsf	CS_STAT3, CS_STAT3_SHIFT_PAGE
	;; always request new display-initialization
	bsf	CS_STAT, CS_STAT_DISPLAY_INIT_REQ
	return
i've marked with <= the added code. in this way you have shift button and 2nd select as play, in main menu window.
hope this help.
G.
p.s. please correct me if i'm wrong in any part, i'm quite new on MIOS.
that definitely looks more complete than my way...
im going to have a go at that.
does r19 have the super cool new drum engine as described by TK?
the nice is, in this way shift page remain on button release. since i prefer slow encoder movement, if you switch on shift page and turn any CS enc, it go slow, switching to others CS page too, sice you come back to main, the speed don't come back to normal.
