Soldering buttons question (OMRON B3F with B3J question).
Hi members :-)
I finally got my MIDIbox up and running with all the pots, so now it is time to move on to the buttons and the DIN/DOUT.
I bought some OMRON B3F/B3J tactile buttons with (as far as I can see) four connectors labeled 1, 2, 3 and 4 and two connectors for the LED.
This is the one:
I can't seem to find any connection information anywhere on the OMRON site, and google didn't help much either.
Any of you have had any experience with these buttons that could tell me where the 1-4 connectors should be connected to my DIN ?
Thanks in advance and for all your help;
KennethA
12bit.com
Hi
lol, look in the right corner below of the picture, there is the pin-description....and as its said, pin1+2 and 3+4 is connected together, so you have the choice, connect pin1 to GND and 3 to DIN, or 2->GND and 4->DIN ;)
EDIT : Or 1->GND....4->DIN    or    2->GND....3->DIN.....  ;D  ;D
Hi
Hi MTE. You're my new best friend.
I don't see what you're referring too as detailed as you are but I am just an amateur.
Thanks.
To the soldering iron !!
KennethA
12bit.com
There is a switch symbol in the picture labelled "Terminal Arrangement/Internal Connections (Top View)"
quote from: http://www.kpsec.freeuk.com/symbol.htm
this also shows pins 1 and 2 are connected, pins 3 and 4 are connected.
So the switch is electrically connected between either pins 1 or 2 ... AND ... either pins 3 or 4.
You then wire this switch up the same way as the push button switch symbol:
you would see here:
http://www.ucapps.de/mbhp/mbhp_dinx4_32buttons.pdf
Thus connect pins 1 or 2 to ground, pins 3 or 4 to the DIN input.
you would see here:
Thanks for the explanation Wilba.
I guess I need to read up on the different symbols :-)
KennethA
12bit.com
