What pic burner to use (other than Pic Burner or JDM module)????
I built the Pic Burner hoping that a USB to Parallel cable would work with it. It doesn't...or at least I can't get P18 to recognize it. I would read the helpfile or e-mail Sprut.de if everything wasn't in german!!!
I don't have a computer with a parallel port (like most people these days).
What USB based programmer can I use to program the PIC18F4620 and PIC18F452.
Is there a simple circuit I can build so that I can use a Pic Kit 2?
Or should I buy something like this: http://www.electrokits.com/electronics/programmers/100.htm
Help greatly appreciated, I need to get these burned ASAP
btw, I could buy them with the boot loader burned in from smash tv but the price of buying four or more chips from him is the same as buying a commercially available burner and then I can get an almost endless supply of free chips from microchip.com as samples.
From another site I found this connection scheme:
PICKit2 pins
1 - VPP to 1 from PIC18F452
2 - VDD to 11 and 32 from PIC18F452
3 - GND to 12 and 31 from PIC18F452
4 - RB7 to 40 from PIC18F452
5 - RB6 to 39 from PIC18F452
6 - not used
I assume PIC18F452 and PIC18F4620 are interchangeable in this situation as well?
Yeh they program the same. One thing to watch out for is that it supports HVP mode, which I think that pinout does?
Yep the above worked.
So personally I would highly recommend buying a pic kit 2 (or clone...eitherway they are under $40) and then you can use the Pic Kit 2 software to program the PICs.
I made the connections listed above on a breadboard in about five minutes and had no problem programming a PIC18F4620
