keefaz Posted July 31, 2008 Posted July 31, 2008 Hi all,I have a problem with the new MIOS programming platform developementI can't compile programming examples/templates in the apps/ directoryThe error is:sdcc: glue.c:1318: pic16emitStaticSeg: Assertion `0' failed.Caught signal 6: SIGABRTmake: *** [_output/main.o] Error 1Now I looked into the _output/app_lcd.lst file and I see that there are a lot of Macintosh newline characters(marked as ^M in vim, it is the character 015 or \r, the newline character on linux should be 012 or \n)I don't know if it is relevant though...I looked all the files in $MIOS_PATH/modules/app_lcd/dummy/but I do not see the \r character on those files...How the _output/app_lcd.lst is created ?I am newbie into Mios programming, but I success to write an application and compile it with an old Makefile(not with the new MIOS programming platform) so I guess my toolchain is correct
stryd_one Posted July 31, 2008 Posted July 31, 2008 The lst file is generated by the compiler... That error is strange, looks like a compiler internal error.I'd like to see two things: The output of sdcc --versionAnd the text that you cropped out of the above - I'd like to be sure it's calling sdcc with the correct params, see if there are other warnings/errors/etc.Edit: sorry got distracted - The linefeeds on my windoze box are windows style (CR+LF, hex is 0x0d,0x0a) ...i would assume that the linefeeds in the lst files would normally match your OS... weird...
keefaz Posted July 31, 2008 Author Posted July 31, 2008 Thanks for the quick reply! sdcc -v SDCC : mcs51/gbz80/z80/avr/ds390/pic16/pic14/TININative/xa51/ds400/hc08 2.5.0 #1020 (Apr 17 2007) (UNIX) And the output from make command in the apps/templates/sdcc_skeleton dir rm -rf _output/* rm -rf _output rm -rf *.cod *.map *.lst rm -rf *.hex mkdir -p _output sh /home/keefaz/mios/bin/mios-gpasm -c -p p18f452 -I./src -I /home/keefaz/mios/include/asm -I /home/keefaz/mios/include/share -I /home/keefaz/mios/modules/app_lcd/dummy -DDEBUG_MODE=0 -DSTACK_HEAD=0x37f -DSTACK_IRQ_HEAD=0x33f -I /home/keefaz/mios/modules/mios_wrapper /home/keefaz/mios/modules/mios_wrapper/mios_wrapper.asm -o _output/mios_wrapper.o sh /home/keefaz/mios/bin/mios-gpasm -c -p p18f452 -I./src -I /home/keefaz/mios/include/asm -I /home/keefaz/mios/include/share -I /home/keefaz/mios/modules/app_lcd/dummy -DDEBUG_MODE=0 /home/keefaz/mios/modules/app_lcd/dummy/app_lcd.asm -o _output/app_lcd.o sh /home/keefaz/mios/bin/mios-sdcc -c -mpic16 -p18f452 --fommit-frame-pointer --optimize-goto --optimize-cmp --disable-warning 85 --obanksel=2 -I./src -I /home/keefaz/mios/include/c -I /home/keefaz/mios/include/share -DDEBUG_MODE=0 main.c -o _output/main.o Processor: 18f452 sdcc: glue.c:1318: pic16emitStaticSeg: Assertion `0' failed. Caught signal 6: SIGABRT make: *** [_output/main.o] Error 1
keefaz Posted July 31, 2008 Author Posted July 31, 2008 BTW, when I use sdcc_skeleton_v1_9a as an app template, everything works fine!I write the programm, then run make command and it compiles/creates the project.hex, which I upload successfully in the PIC with MIDI via mios studio and the app run well..[edit]The \r characters appear also in the project.lst created in the sdcc_skeleton_v1_9a template dir,so I guess the error in MIOS programming platform template is not caused by those characters...must comes from elsewhere....At least I have a working solution, but I am curious and wonder why the new templates don't work on my system
stryd_one Posted July 31, 2008 Posted July 31, 2008 sdcc -vSDCC : mcs51/gbz80/z80/avr/ds390/pic16/pic14/TININative/xa51/ds400/hc08 2.5.0 #1020 (Apr 17 2007) (UNIX) Older than dirt!This is current:sdcc --versionSDCC : mcs51/gbz80/z80/avr/ds390/pic16/pic14/TININative/xa51/ds400/hc08 2.8.0 #5117 (Mar 23 2008) (MINGW32)MIOS supports 2.7+
keefaz Posted July 31, 2008 Author Posted July 31, 2008 Ok, the sdcc upgrade to 2.8.0 solved the problem!the skeleton app compilation worked on first tryThank you stryd_one !*I admit I hesitated before the sdcc upgrade because I had a working setup, but I wanted the advantages of the fabulous MIOS programming platform, very good job!
stryd_one Posted July 31, 2008 Posted July 31, 2008 Yay :) You'll be glad you upgraded, SDCC has been vastly improved since 2.5. It outputs lighter code, has new features, and is far more robust.
