Duggle Posted June 23, 2003 Report Posted June 23, 2003 hiIve programmed the 18F with the primary bootloader V1_1.Im using a well worn MBHP MB64.I'm getting the short string sent every two seconds.I think Ive set up midiOX right with only the midiout port enabled, but I get " SysEx Output Devices:The port is transmitting data to the device. Wait until the data has been transmitted, and then try again."thanks for any help or suggestions
Duggle Posted June 23, 2003 Author Report Posted June 23, 2003 It works!Setting low level buffers to size:128 Â num:16 (NOT size:128 num:8 ) fixes this for me.all the best :)
TK. Posted June 23, 2003 Report Posted June 23, 2003 Cool!Duggle, could you please try the following setting - this will be the upcoming suggestion, but I want to ensure that it works on all systems w/o problems: buffer size 2048, number of buffers: 4Best Regards, Thorsten.
Duggle Posted June 24, 2003 Author Report Posted June 24, 2003 hi thorsten,yes, the settings {size 2048 num 4} work fine.regards
