moonskin Posted August 8, 2008 Posted August 8, 2008 I'm trying to teach myself how the scan matrix examples work and was wondering if someone could give me a start here.In the button handler code there is this...;; shift 8 times SM_BUTTON_HANDLER_SHIFT 7 SM_BUTTON_HANDLER_SHIFT 6 SM_BUTTON_HANDLER_SHIFT 5 SM_BUTTON_HANDLER_SHIFT 4 SM_BUTTON_HANDLER_SHIFT 3 SM_BUTTON_HANDLER_SHIFT 2 SM_BUTTON_HANDLER_SHIFT 1 SM_BUTTON_HANDLER_SHIFT 0Is this section getting values from 8 pins of the DIN for 1 of DOUT or is it getting 1 DIN pin for each of the 8 DOUTs?Is the loop below looping through the DIN pins or the DOUTs? ;; loop 8 times incf SM_BUTTON_COLUMN, F, BANKED movlw 8-1 cpfsgt SM_BUTTON_COLUMN, BANKED rgoto SM_ButtonHandler_InnerLoopWhich of DIN or DOUT is the column and which is the row?(What I want to get to eventually is 64 DIN pins with 8 DOUT's to scan organ keyboards/stops with debouncing.)ThanksGraham
jimhenry Posted August 8, 2008 Posted August 8, 2008 I think DOUT is the column and DIN is the row. There is a parameter to reverse the polarity of the diodes but I don't know if that affects the row/column terminology. It might be useful to look at sm_fast.inc as modified by QBas for the 32x32 scan matrix to see how the size of the matrix was altered.
jimhenry Posted August 13, 2008 Posted August 13, 2008 Now Graham and I are both trying to really understand sm_fast.inc so that we can create some switch matrix projects. I have commented SM_Init thusly:;; -------------------------------------------------------------------------- ;; FUNCTION: SM_Init ;; DESCRIPTION: This function initializes the scan matrix. ;; It should be called from USER_Init ;; IN: - ;; OUT: - ;; USES: BSR ;; -------------------------------------------------------------------------- SM_Init ;; set button value to initial value (1) for all 64 buttons in data buffer lfsr FSR0, SM_ROW0_VALUE ; FSR0 <- first row address movlw 0x08 ; set Reg F as row loop counter movwf TMP1 SM_Init_Loop1 setf POSTINC0 ; set all bits for row and increment row address decfsz TMP1, F ; dec loop counter rgoto SM_Init_Loop1 ;; init values of all 64 buttons lfsr FSR0, SM_ROW0_VALUE ; FSR0 <- first row address movlw 0x08 ; set Reg F as row loop counter movwf TMP1 SM_Init_Loop2 setf POSTINC0 ; set all bits for row and increment row address decfsz TMP1, F ; dec loop counter rgoto SM_Init_Loop2 ;; deselect all columns by setting the DOUT data bit and shifting through all registers bcf SM_SRIO_LAT_SCLK, SM_SRIO_PIN_SCLK ; clear the shift clock bsf SM_SRIO_LAT_DOUT, SM_SRIO_PIN_DOUT ; set DOUT data bit movlw 16 ; 16*8 shifts for up to 16 shift registers movwf TMP1 ; Reg F is the register loop counter SM_Init_Loop3 ; set and clear the DIO Shift Clock 8 times to shift through one pair of registers bsf SM_SRIO_LAT_SCLK, SM_SRIO_PIN_SCLK bcf SM_SRIO_LAT_SCLK, SM_SRIO_PIN_SCLK bsf SM_SRIO_LAT_SCLK, SM_SRIO_PIN_SCLK bcf SM_SRIO_LAT_SCLK, SM_SRIO_PIN_SCLK bsf SM_SRIO_LAT_SCLK, SM_SRIO_PIN_SCLK bcf SM_SRIO_LAT_SCLK, SM_SRIO_PIN_SCLK bsf SM_SRIO_LAT_SCLK, SM_SRIO_PIN_SCLK bcf SM_SRIO_LAT_SCLK, SM_SRIO_PIN_SCLK bsf SM_SRIO_LAT_SCLK, SM_SRIO_PIN_SCLK bcf SM_SRIO_LAT_SCLK, SM_SRIO_PIN_SCLK bsf SM_SRIO_LAT_SCLK, SM_SRIO_PIN_SCLK bcf SM_SRIO_LAT_SCLK, SM_SRIO_PIN_SCLK bsf SM_SRIO_LAT_SCLK, SM_SRIO_PIN_SCLK bcf SM_SRIO_LAT_SCLK, SM_SRIO_PIN_SCLK bsf SM_SRIO_LAT_SCLK, SM_SRIO_PIN_SCLK bcf SM_SRIO_LAT_SCLK, SM_SRIO_PIN_SCLK decfsz TMP1, F rgoto SM_Init_Loop3 ; loop though 16 pairs of registers ;; latch DOUT values that were shifted in by clearing and setting the DIO Register Latch Pin bcf SM_SRIO_LAT_RCLK, SM_SRIO_PIN_RCLK nop nop nop bsf SM_SRIO_LAT_RCLK, SM_SRIO_PIN_RCLK return Do have this much right?Why are the row values set twice, once in SM_Init_Loop1 and then again in SM_Init_Loop2?
TK. Posted August 16, 2008 Posted August 16, 2008 Why are the row values set twice, once in SM_Init_Loop1 and then again in SM_Init_Loop2?This seems to be a copy&paste error, in this variant:http://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Fapps%2Fexamples%2Fsm_c_example2%2Fsm_fast.asmthe debounce counters are cleared insteadI think, that the second loop can be savely removed - could you please doublecheck this?I could give you write access to the repository, so that your additional comments won't get lostBest Regards, Thorsten.
jimhenry Posted August 17, 2008 Posted August 17, 2008 I think, that the second loop can be savely removed - could you please doublecheck this?I could give you write access to the repository, so that your additional comments won't get lostQBas removed the second loop in his scan matrix enhancements. I removed the second loop with no apparent ill effects. I think it is confirmed that it can be safely removed.I will contact you regarding repository access when I think my update is ready.Best Regards,Jim Henry
jimhenry Posted August 19, 2008 Posted August 19, 2008 SM_DOUT_VALUE is a 1 of 8 bit code for the *next* column to be selected by DOUT: ;; determine DOUT value for *next* iteration step ;; this value gets active with the next latch pulse incf SM_BUTTON_COLUMN, W, BANKED call MIOS_HLP_GetBitANDMask ; (inverted 1 of 8 code) movwf SM_DOUT_VALUE, BANKED The SM_BUTTON_HANDLER_SHIFT MACRO is used 8 times in each loop of a column select to shift in the 8 bits of the DIN and shift out bits according to SM_DOUT_VALUE to set up DOUT for the next latch which will select the next column. This is the code that chooses when to shift the 0 into the DOUT shift register for the next column select: ;; set DOUT value bsf SM_SRIO_LAT_DOUT, SM_SRIO_PIN_DOUT btfss SM_DOUT_VALUE, 7-bit_number bcf SM_SRIO_LAT_DOUT, SM_SRIO_PIN_DOUT Because btfss tests bit (7-bit_number) column 0 is selected by Q7 of the DOUT register, column 1 by Q6, and so on. I tried changing the test to simply: btfss SM_DOUT_VALUE, bit_numberThere were no obvious problems and Q0 selected column 0 etc. which seems easier to deal with for wiring. Any subtlety I'm overlooking?
John_W._Couvillon Posted February 19, 2011 Posted February 19, 2011 Jim Henry, I know that your post is old, but what ever happened to your work on the matrix project? Johnc
