sllam Posted August 14, 2008 Posted August 14, 2008 Yeah so I was thinking...with a dj midi controller like this..http://digital.dj/articles/dj-hardware/m-audio-x-session-pro-usb-midi-controller.htmlcould i also buy a seperate jog wheel midi controller and have them work together// is tha even possible or is theere even a dj midi jog wheel controller/
Sasha Posted August 14, 2008 Posted August 14, 2008 HI Sllam and wellcome aboard. I`m asking myself, have you maybe register at wrong forum...We are DIY crowd here, and your first post is about pairing commercial product to another commercial product, and that don`t have anything in common with self made controllers except it is all MIDI gear.If you are willing to make yourself much better controller and pair it with high resolution optical jog, all DIY, than you should start reading. If not, i believe there are much suitable DJ tech forums where you`ll find your answers. ;) Good luck and I hope you`ll stay.
Screaming_Rabbit Posted August 14, 2008 Posted August 14, 2008 could i also buy a seperate jog wheel midi controller and have them work together// is tha even possible ... depends on your software, if it allows you to specify more than one controllers. Otherwise there would be the possibility (with MIDI, not USB gear) to use a MIDI Merger.... or is theere even a dj midi jog wheel controller/http://www.jlcooper.com/pages/mcs3usb.html... there is also a MIDI version available.Greets, Roger
