Goblinz Posted September 16, 2008 Posted September 16, 2008 This may seem to be a bit of a strange question but I can explain why I need this via PM if anybody can help. I need to access a windows XP PC that is password protected which I have physical access to. Does anybody have any ideas on how to do this. I seem to remember some sort of bootdisk for windows NT where you could get in to the file system and decrypt the password file. G
stryd_one Posted September 16, 2008 Posted September 16, 2008 There are like 50 squillion downloadable ISOs which you can boot to and simply overwrite the administrator password. Very quick and easy, you'll be done within 5 minutes.The one I use is proprietary so I can't make a recommendation, but one linux based security boot CD is as good as another. ntpasswd / chntpw are a tool that'll do it, and the name has bootdisks at http://home.eunet.no/~pnordahl/ntpasswd/If you want to, you can also use the install CD, but it's more messing around than I usually can be bothered with.
