Travischen Posted October 10, 2008 Report Posted October 10, 2008 Been trying to figure this one out for a while with no luck. I am using a Mac to run the MBSIDV2 Editor. I initially was able to run the program fine and it was awesome! A few days later, I tried to run the program and I get the following exception. I am using a M-Audio 2x2 and I have mmj installed. Exception in thread "main" java.lang.NullPointerException at org.midibox.midi.MidiDeviceRouting.disconnectDevices(MidiDeviceRouting.java:176) at org.midibox.midi.MidiDeviceRouting.setInputDevice(MidiDeviceRouting.java:121) at org.midibox.apps.SIDV2librarian.SIDV2librarian.recallConnections(SIDV2librarian.java:74) at org.midibox.apps.SIDV2librarian.SIDV2librarian.<init>(SIDV2librarian.java:47) at org.midibox.apps.SIDV2librarian.SIDV2librarianGUI.main(SIDV2librarianGUI.java:537)I've tried restarting, unplugging the midi, deleting the MBSIDV2 files and re downloading them. No luck... Any ideas? Quote
Travischen Posted October 11, 2008 Author Report Posted October 11, 2008 Not really sure why but I tried again this morning and everything works... ;D Quote
Travischen Posted October 23, 2008 Author Report Posted October 23, 2008 Grrr, this problem is happening to me again. I've been trying to figure it out for the last couple hours with no luck... not sure why it works one day and I get the exception the next. Does anybody have any insight or have experienced similar problems? Quote
stryd_one Posted October 23, 2008 Report Posted October 23, 2008 My guess is that MMJ or your midi interface are causing the problem... Have you power cycled the machine? Checked the logs? What do they say? Quote
