Guest Da5id Posted September 6, 2003 Posted September 6, 2003 So, i take it i2s (whoops, was I calling it i2c before? :) ) doesn't have any nasty cable length restrictions?I suppose i2s would be the easiest, otherwise incoming audio would have to be first run through a DAC and then converted to ADAT or SPDIF and then re-converted to i2s again for the emu10k1... Icky.
pilo Posted September 6, 2003 Posted September 6, 2003 yes I2S output are better wy because most of the DAC and ADC works with I2S :)the ADAT solution is not very expensive : ADAT encoder (4 I2S to 1 ADAT) chip $5, the decoder (1 ADAT to 4 I2S) chip $7... rj45 cable + driver I don't know exactly, or Toslink connector and lightpipe.I think SPDIF can work well with length... I2S... hummGilles do you know a chip that convert SPDIF to I2S? I'm going to look for it.FOr Da5id : luckily, I2S is used by ADAT chip, SPDIF chip, ADC and DAC. That's why it's an interesting protocol becase we can convert it to what we want :) (and vice versa)Oh Gilles, do you know exactly how ADAT s/mux works? and do you have any info on the ADAT protocol?Thank you guys ;)
d2k Posted September 7, 2003 Posted September 7, 2003 Pics of the ADC brd so far :)And those pcms were done using this clapped out soldering iron i got from the local newsagents yrs ago :P - my 'decent' one broke :/But ebay got me this :)http://ebay0.ipixmedia.com/abc/M28/_EBAY_9beb27346ba0928c24466ada6eb86a18/i-1.JPGBestDan
Guest Da5id Posted September 12, 2003 Posted September 12, 2003 OK, before part of the database got munched, I posted asking what toner transfer method you were using. You replied, saying you used the backing from "tacky-back plastic".So, could you be more specific? is this computer label paper? Adhesive-backed vynil? Any detail would be appreciated!Thanks!
d2k Posted September 13, 2003 Posted September 13, 2003 So, could you be more specific? is this computer label paper? Adhesive-backed vynil?It comes in a roll, and is normally used to cover artwork and such - u get it from the stationers...Yes, u can also use the avery labels mentioned on another thred. Go to the printer paper section of ur local office supplies (or such) shop...BestDan
Guest Da5id Posted September 13, 2003 Posted September 13, 2003 Great, thanks!I'll pick some up and give it a whirl.
uclaros Posted September 13, 2003 Author Posted September 13, 2003 Hi guys!Can someone send me the files for the 4xPCM board?send it please to uclaros-at-yahoo-dot-comThanks pilo, or dan, or gilles or whoever send it anyway!!!
pilo Posted September 13, 2003 Posted September 13, 2003 for the PCB... I think we have to design it again, because we didn't pay attention to the noise issues... Dan, Gilles, Smash and me have to chatter to see what is the best way... But I think maybe one PCB per ADC will be easy to make... 24bits ADC PCB are very very hard to make, we have to care about a lot of stuff to deal with the datasheet specs (ie to use 24bits for sound, and not 16 for noise and 8 for sound :)).We have also to design a balanced input driver... But it will not take a lot of time.And every people interest in help me for the website is WELCOME! school takes me a lot of time, and so I can't spend to much time on that...By the way, we will also make a AES/SPDIF input/output board and the ADAT thing soon :)
hallucinogen Posted September 14, 2003 Posted September 14, 2003 hithis is really hot !!which of the inputs are used for the 4 stereo adc´s?the kx prolog gives:AC 97 l/r - the normal analog incd spdif l/r - the int. cd spdif ini2s/spdif l/r -??coax/optical l/r - on my hoontech sblive add on line2/mic2 l/r -??unknown2 l/r -??aux2 l/r -??im using two sblive 4.1 as a/d and plugged them in cd spdif and the hoontech add on card spdif in.this way i can record 6 mono tracks a time.would your board make it possible to get all 8-?? ins ??to get all 14 ;D ;D ??hallucinogen
uclaros Posted September 14, 2003 Author Posted September 14, 2003 OK Pilo!I'll wait for the full PCB!I'm afraid I can't help in the design since I'm only an electronic hobbyist...I could give u an aid for the site though if you like!
pilo Posted September 14, 2003 Posted September 14, 2003 mmmm I'm working on the ADAT input/output right now :)I'm going to look at the ADC board later in the afternood too.For the inputs : yes with 4 ADC you will have 14 inputs :) 1 AC97 input, 4 I2S input (don't remember the name in KX mixer) <- this is where we need ADCs, and 2 SPDIF
hallucinogen Posted September 14, 2003 Posted September 14, 2003 whooaa !all 14 in thats ;D ;D ;D ;D ;D ;D
drumwide Posted September 14, 2003 Posted September 14, 2003 hello everyone, I've got  the first .brd file from pilo and I have been trying to modify it for balanced operation.I have ordered parts frome Texas Instruments:         Balanced Line Receiver:     INA134PA         Analog- Digital Conversion:   PCM1804DB         Digital -Analog Conversion:   PCM1737E         Balanced Line Driver:     DRV134PAif you all are using different parts please let me know.When you guys decide on what parts you will use please let me know so I can order the same parts you do, so correspondence of development will be easier.and also if you guys get new schematics will you let me know or pass them on to me through email?thanx
pilo Posted September 14, 2003 Posted September 14, 2003 the PCM1804 has BALENCED input! so you can plug balenced line in without converted it!! :)for ADC board, don't make it until we test and maybe redesign it! ;)
gillesdeshays Posted September 16, 2003 Posted September 16, 2003 now we have a board on the SBlive mod :10k1BOX project ;DFor now the mailer isn't working ... but when you register .. it works... evenif it doesn't send you an email to confirm .....enjoy the place and share your ideas !;)
uclaros Posted September 16, 2003 Author Posted September 16, 2003 **Problems with your site!!! Y don't u use YaBB? it's a great forum!phpBB : Critical Error Could not open terayon template config fileDEBUG MODELine : 326File : /var/www/free.fr/18/m/i/d/i/midiboxtracks/phpBB2/includes/functions.php
gillesdeshays Posted September 16, 2003 Posted September 16, 2003 yep . i made something wrong .......it will be ok in a few ! :-[
gillesdeshays Posted September 16, 2003 Posted September 16, 2003 here is the final link !10k1BOX Project ;D
d2k Posted September 16, 2003 Posted September 16, 2003 w00t :DNice1 gilles - i was just about to do go in and start a site meself! :P no need to now....Let the i/o commence!!BestDan
gillesdeshays Posted October 2, 2003 Posted October 2, 2003 just to up this topic ! 8) 8) 8) 8) 8) 8) 8) 8)
gillesdeshays Posted October 7, 2003 Posted October 7, 2003 10k1box.free.fr is updated and moved to a new server .... with emailer functions .....Now, no apologizes to say that you didn't know someone answer your topic ! ;) 8)
Guest adeser Posted November 7, 2003 Posted November 7, 2003 can I use the adc.gif diagram (the one with CS5331 and CS8402) for converting an analog signal to s/pdif input on my m-audio Audiophile sound card ?
pilo Posted November 8, 2003 Posted November 8, 2003 yes this may works I think :)but the CS chip are "hard" to find... Texas has some chip too (you can order sample!!!)
