Hendrik Posted January 1, 2009 Report Share Posted January 1, 2009 Frohes neues Jahr erstmal,wollte in der oben angegebenen Datei LEDDIGITS_ENABLED auf 1 setzen und dann neu kompilieren.Dazu habe ich ein leeres Projekt in MPLAB erstellt, die Datei setup_midibox_lc.asm hinzugefügt und dort die 0 auf 1 geändert.Wenn ich dann jedoch auf Make klick, kommen folgende Fehler:Executing: "C:\Programme\MPLAB IDE6\MCHIP_Tools\mpasmwin.exe" /q /p18F452 "setup_midibox_lc.asm" /l"setup_midibox_lc.lst" /e"setup_midibox_lc.err" Error[113] D:\MIDI\SETUP_MIDIBOX_LC.ASM 148 : Symbol not previously defined (MIOS_ENC_MODE_NON_DETENTED) Error[113] D:\MIDI\SETUP_MIDIBOX_LC.ASM 148 : Symbol not previously defined (MIOS_ENC_MODE_NON_DETENTED) Error[113] D:\MIDI\SETUP_MIDIBOX_LC.ASM 148 : Symbol not previously defined (MIOS_ENC_MODE_NON_DETENTED) Error[113] D:\MIDI\SETUP_MIDIBOX_LC.ASM 148 : Symbol not previously defined (MIOS_ENC_MODE_NON_DETENTED) Error[113] D:\MIDI\SETUP_MIDIBOX_LC.ASM 148 : Symbol not previously defined (MIOS_ENC_MODE_NON_DETENTED) Error[113] D:\MIDI\SETUP_MIDIBOX_LC.ASM 148 : Symbol not previously defined (MIOS_ENC_MODE_NON_DETENTED) Error[113] D:\MIDI\SETUP_MIDIBOX_LC.ASM 148 : Symbol not previously defined (MIOS_ENC_MODE_NON_DETENTED) Error[113] D:\MIDI\SETUP_MIDIBOX_LC.ASM 148 : Symbol not previously defined (MIOS_ENC_MODE_NON_DETENTED) Error[113] D:\MIDI\SETUP_MIDIBOX_LC.ASM 148 : Symbol not previously defined (MIOS_ENC_MODE_NON_DETENTED) Error[129] D:\MIDI\SETUP_MIDIBOX_LC.ASM 171 : Expected (END) Halting build on first failure as requested. BUILD FAILEDIch habe an der Datei ansonsten nichts verändert.Kann mir jemand sagen, woran das liegt?Greetz ;) Quote Link to comment Share on other sites More sharing options...
stryd_one Posted January 1, 2009 Report Share Posted January 1, 2009 Sorry for English.Hendrik asked about this in the chat but I missed him and didn't get to tell him the answer...Download the new zip and setup the new toolchain:Quick Start Guide Toolchain Setupmidibox_lc_v1_6c.zipEnjoy :) Quote Link to comment Share on other sites More sharing options...
Hendrik Posted January 1, 2009 Author Report Share Posted January 1, 2009 Wonderfull present for the new year. Thank you a lot! Quote Link to comment Share on other sites More sharing options...
