xarolium Posted January 8, 2009 Posted January 8, 2009 hi everybody,i would like to know if i use 6 pin resistor network for R39 , i don't have to sold R58because there isn't connect between the last pin of the resistor network and R58like in the pictureBut there is one for R57 Is this a missing??? ??? ??? ???
Wilba Posted January 8, 2009 Posted January 8, 2009 If using a 6-pin resistor network in R38,R36,R34,R32,R30, the 6th pin (the pin not inside the white box) serves as 10K pullup which would make R57,R58,R59,R60,R61 redundant.The exact substitution list is:6th pin in R38 => R576th pin in R36 => R586th pin in R34 => R596th pin in R32 => R606th pin in R30 => R61You might be getting confused because of the placements.... it's actually the 6th pin in R36 which is connected to U19 pin 10, U20 pin 9 and R58.... and the 6th pins of R39,R37,R35,R33,R31 are not being used.
Wilba Posted January 8, 2009 Posted January 8, 2009 ALSO those capacitors look very big!If you intend to use the MB-6582 control surface PCB in a PT-10 case, the lower edge of the control surface PCB gets very close to the IC's U20,U19,U18,U17,U16. Those capacitors cannot be much taller than the IC+socket. (I expected people would use small monolithic ceramic capacitors here, as shown in the parts list). Also they make taking out the ICs harder, not that you would need to I suppose.
xarolium Posted January 8, 2009 Author Posted January 8, 2009 ok thank you for the fast answerlike you said i was confused by the position of the resistorand for the caps do you think i need to change it?
Wilba Posted January 9, 2009 Posted January 9, 2009 and for the caps do you think i need to change it?Maybe. Check if it is taller than an IC+socket. If it's shorter than IC+socket height, then you don't have to change it. If it's taller than IC+socket height, then it might be too close to the CS PCB. I'm sorry I can't give a better answer - I would have to disassemble my MB-6582 to measure the actual height above PCB - I only know that there is clearance for the IC+socket and maybe an additional 1mm. (FYI I knew it would be close before I built the prototype and fully anticipated using low-profile IC sockets or *shock* *horror* soldering the 74HC165 to the PCB if neccessary).If you are using this capacitor size here, where else are you using it? What about the capacitors inside IC sockets, and in the audio buffer above the SID ICs? All the capacitors I use are either small ceramic (<100nF), monolithic (>=100nF) or electrolytic (>=1uF)... (ok and some nice 22nF SID filter caps).
xarolium Posted January 9, 2009 Author Posted January 9, 2009 Here is the picture no problem for the caps in the core and in the Siddo you think it's ok the high of the caps to close the box Pactec 10?
Wilba Posted January 9, 2009 Posted January 9, 2009 That should be fine then. There is clearance to the top of the ICs, the caps are shorter, so it's OK.
