Sephult Posted July 10, 2003 Report Posted July 10, 2003 Hello!I am looking for information regarding the MIOS tables.I am wanting to convert my 8 DIN to be controlled by note on/off messages rather than controllers. I am taking this message in the MIOS tables file to be the section I am looking for128 buttons and LEDs assigned to MIDI events "B0 00 <value>" to "B0 7F <value>"Is this correct.If so is there a list of strings that correspond to the values? If not I will try to compile one.\Thanks-Sephult Quote
TK. Posted July 14, 2003 Report Posted July 14, 2003 Hi Sephult,a list of MIDI events can be found here:http://www.borg.com/~jglatt/tech/midispec.htmIt would be very helpful if you could compile a special list for MIOS users (it could be included under HOWTOs->mios_tables.inc) - the coding is simple when hexadecimal numbers are used:B stands for "MIDI controller"0 for the MIDI channel (0-15 == channel 1-16)the next 7-bit value indicates the MIDI controller numberNote On events: use 9 instead of BNote Off events: use 8 instead of Bthe next 7-bit value indicates the note numberIf the two bytes of a table entry are matching with the received MIDI event, the USER_MPROC_NotifyFoundEvent function will be called by MIOS. The first two MIOS_PARAMETER[12] variables contain the same bytes like the appr. table entry, the third variable (MIOS_PARAMETER3) contains the CC value (on MIDI controller events) or the velocity value (on note On/Off events)Special case: if a Note On event with velocity == 0x00 has been received, it has to be handled like a Note Off event (see MIDI specification)Best Regards, Thorsten. Quote
stryd_one Posted July 14, 2003 Report Posted July 14, 2003 I'll be happy to put that list together if sephult hasn't almost finsihed it already :) Quote
Sephult Posted July 14, 2003 Author Report Posted July 14, 2003 Definitely, The more help the merrier. We can get a massive DIY Tutorial going stryd.Thanks Thorsten! Quote
