Guest zomoipotoi Posted July 17, 2003 Posted July 17, 2003 Someone knows if MidiBox SID have MIDI Merge?Thanks!!
TK. Posted July 17, 2003 Posted July 17, 2003 Yes, but only the MIOS based firmware. The merger function had to be switched on/off with the "Link" button, but you can also change the init function to enable the merger by default.Best Regards, Thorsten.
Guest zomoipotoi Posted July 19, 2003 Posted July 19, 2003 Thanks!I immediatly upgrade my "old" SID to MIOS, 'cause I need MIDI Merge.Best Regards, Dario.
