omnitek Posted May 28, 2009 Report Share Posted May 28, 2009 Hi,I'm want to built a basic Midibox Sid (Core + Sid board only) that I would control with a midi keyboard controller.Right now I assembled the boards and tested them with the MBSID_TESTTONE application and I'm getting a sound coming out of the audio output.My question is: Do I need to create my own application or may I use the Midibox SiD V2 application to be able to control my Sidbox with a midi keyboard controller?Thanks for your help!Nicolas Quote Link to comment Share on other sites More sharing options...
Wilba Posted May 28, 2009 Report Share Posted May 28, 2009 You can control the MIDIbox SID V2 application with a MIDI keyboard controller.I suggest you read the User Manual: http://www.ucapps.de/midibox_sid_manual.htmland perhaps read the "V1 Upgrade" section, making sure you've added the 1K pull-up for the CAN bus.There is patch editor software you can use to create/upload patches, if you do not have a control surface: http://www.midibox.org/forum/index.php/topic,11935.0.html Quote Link to comment Share on other sites More sharing options...
