Migrating a project to Codeblocks produces linking errors (missing definition fo
Hello people!
I'm starting my way programming in c, and made my first steps using Notepad++. Everything was ok, but then I saw that with Acsim i could test my apps without flashing the pic. So, following the instructions in the wiki I started to setup Codeblocks and all the needed other things for ACsim to work.
It's been complicated, but everything seems to be right. Everything but:
I have a project based on mclock, where there's main.c and mtc.c, with their respective headers.
When I try to bulid the project, either as debug or release I get the error:
error: missing definition for symbol "_MTC_DoRew", required by "_output\main.o"
error: missing definition for symbol "_MTC_DoStop", required by "_output\main.o"
error: missing definition for symbol "_MTC_DoPlay", required by "_output\main.o"
error: missing definition for symbol "_mtc_state", required by "_output\main.o"
error: missing definition for symbol "_MTC_Timer", required by "_output\main.o"
error: missing definition for symbol "_MTC_Tick", required by "_output\main.o"
error: missing definition for symbol "_MTC_Init", required by "_output\main.o"
error: missing definition for symbol "_MTC_DoFwd", required by "_output\main.o"
error: missing definition for symbol "_MTC_FPSSet", required by "_output\main.o"
error: missing definition for symbol "_MTC_DoPause", required by "_output\main.o"
error: missing definition for symbol "_mtc_long_timeMSW", required by "_output\main.o"
error: missing definition for symbol "_mtc_long_timeLSW", required by "_output\main.o"
ERROR!
Process terminated with status 1 (0 minutes, 1 seconds)
0 errors, 1 warnings
It seems it cannot find the definitions in mtc.h
Although they are just as they were when using Notepad++ and there was no trouble at all.
I copy the start of main.c, and some parts of mtc.h
// Include files
#include "main.h"
#include "mtc.h"
//#include <cmios.h>
//#include <pic18fregs.h>
#ifndef _DEBUG_C
#include "cmios.h"
#include "pic18f452.h"
#endif
mtc.h:
#ifndef _MTC_H
#define _MTC_H
// Global definitions
// Global Types
// status of MTC
typedef union {
  struct {
    unsigned ALL:8;
  struct {
    unsigned RUN:1;
    unsigned PAUSE:1;
    unsigned START_REQ:1;
    unsigned STOP_REQ:1;
    unsigned CONT_REQ:1;
} mtc_state_t;
// Prototypes
void MTC_Init(void);
void MTC_Tick(void);
void MTC_Timer(void);
void MTC_FPSSet(unsigned char rate);
unsigned char MTC_FPSGet(void);
void MTC_ResetMeter(void);
void MTC_SendMeter(void);
void MTC_DoStop(void);
void MTC_DoPause(void);
void MTC_DoPlay(void);
void MTC_DoRew(void);
void MTC_DoFwd(void);
unsigned int MTC_GetTimerValue(unsigned char rate);
____________________________
As you can see, mtc.h is included in main.c, an the functions not found by the linker are declared in mtc.h. So, it's puzzling me beyond my efforts. I know it must be some stupid thing I'm overlooking, but, well, I spent many hours and couldn't find a solution.
Thanx for your wise advice
Pablo
Hi Pablo,
I never used CodeBlocks, so I'm not sure if I can be of any help, but if it worked in Notepad++ but not in Codeblocks, I guess there might be something wrong with the make-process. With the old toolchain, one had to add additional classes to the Makefile (OBJS = mtc.o)... again, not sure if this is done automatically by adding files to a target in CodeBlocks...
Best,
Michael
Hi!
If I understood you well, I took makefile and where it said
OBJS=$(OUTDIR)/pic18f452.o $(OUTDIR)/main.o
I added mtc.o so it now reads
OBJS=$(OUTDIR)/pic18f452.o $(OUTDIR)/main.o $(OUTDIR)/mtc.o
Sadly, I got the same error, and what's more, once the project is built, makefile returns to it's original state.
thank you, anyway!
Heya pablop :)
You mean this one ?
Did you maybe use the template in the zip file from this section ? It's verrrry olllld and won't work...
You should be able to follow the instructions for creating a new template found here though, but you will need to change at least one step:
Where it says to type 'make.bat' you just type 'make'.
There may be other changes required.... That documentation is quite old...
Thanx, Stryd, I followed your instructions and everything worked ok!
I've just posted something about MIOS_Timer not working on GUISim, though, heh, there's always something new to stumble upon! ;-)
Cya
Pablo
