LoneStar Posted May 31, 2009 Posted May 31, 2009 Greetings,I'm using the MIDIO128 for MIDI-controlled switching purposes using 4066 (quad cmos switches) controlled by DOUT.I can configure the MIDI-In behavior to my liking in the .ini file (Note on -> DOUT pin 5V, Note off -> DOUT pin 0V etc).In the given configuration, any DOUT pin follows the state of the corresponding DIN pin (given it is enabled in the ini file).How could I change the DIN-DOUT forwarding from edge-driven to toggle, so I can use pushbuttons to switch the DOUT pins on/off?Regards,LoneStar
stryd_one Posted June 1, 2009 Posted June 1, 2009 Welcome aboard LoneStar :)Try @Toggle in the ini file :)
LoneStar Posted June 1, 2009 Author Posted June 1, 2009 Welcome aboard LoneStar :)Try @Toggle in the ini file :)Thanks for the welcome :)Unfortunately, the @Toggle in the ini file only determines how the DOUT pins react upon incoming midi messages.My problem is, how do I get the same on the DIN-DOUT forwarding? All there is is an option to turn forwardingon/off, when on the DOUT pins simply follow the DIN pins. What I want it to do is a DIN pin toggling the correspondingDOUT pin, as in DIN low -> DOUT high, DIN high again -> DOUT stays high, next time DIN low -> DOUT lowI reckon I'll have to change the DIN handler code for that. Unfortunately my programming skills are practically not present.
