When testing my C64 PSU I read a stable 5.24 V on the 5VDC lines. The AC-lines only give 3.2 V, but should be delivering about 9V. I know the PSU did deliver just a bit above 9V when testing it for the first time, so therefore I reckon that something must have died..
Since it does give some voltage on the VAC-line, that gives a little hope. On the other hand I have the 'brick' PSU version (the square ribbed one) that came with a C64C and also has no access to the fuses from the outside (not that I would need that right now, since a burnt fuse would give me 0VAC, right?). There seems no option to open the PSU, except for brute force ;) As I don't want to waste a lot of time with a screwdriver and hammer to open it up and then discover that there's nothing to repair inside, I need some advice.
Is this type of PSU also filled with epoxy and therefore unservicable? In other words, should I throw this one away and find a new power supply?
Are you measuring 3.2V on the AC lines using AC setting on your multimeter?
If so, there's not much hope fixing this PSU. Internally, it's just a transformer with two 9V AC secondary coils, one leads directly to the output pins, the other goes through a bridge rectifier/voltage regulator to supply 5V DC. I'm no expert but getting less than 9V AC on the AC output pins suggests a short somewhere on that coil, i.e. less coils, less output voltage. As far as I know, fuses either pass all the voltage or burn out and pass nothing, not drop the voltage.
The 3.2 volts are indeed measured with AC selected on the multimeter. Thanks for your information about the internals of the PSU, I'll better spend some time looking for a different PSU, instead of trying to fix this one.
