is a 'correct' MIDI interface really needed?????
PC owners have to use a MIDI interface cable so that they can interface to a MIDI machine such as MBox64.
The core must therefore have a complimentary MIDI interface including an opto-isolator etc etc.
But as the opto-isolator is only present to prevent ground loops (which usually only occours when lots of gear is used) and affords no so-called 'protection' for the core pic, I wonder why on earth spend out on the things which are not required?
Surely a simple buffer between Pic and Games port would suffice???
Cheers all  :)
Cheers for the reply.
It makes sense to me: use the least to get the same (or better) result. Its surprising how many think the opto-isolator is there to protect expensive chips.
Interesting project you have there Thorsten, thanks a lot.
