Hello all,
Currently building a V2 seq using a 452 pic I already had laying around.
I want the unit to be minimal with only one 2x40 lcd and eight encoders, eight leds, and rows of eight buttons.
I understand that with a single 2x40 display tracks 9-16 are displayed when a button or encoder is activated for one of those tracks.
Can I get the leds and encoders to shift from tracks 1-8 to tracks 9-16 as well?
Is there some kind of shift button I include in the code to do this?
I'm not very good with code, so simple is the best policy.
-D
you could implement such a SHIFT button on a similar way like "SEQ_BUTTON_All" (just toggle a flag stored in a memory location). Thereafter you have to change SEQ_BUTTON_GP, so that an offset of 8 is added to button 0-7 when the SHIFT function is activated, and you have to modify SEQ_LED_UpdateIRQ, so that either IRQ_TMP1 or IRQ_TMP2 is transfered to the "DEFAULT_GP_DOUT_SR0 - 1" shift register.
Thanks Tk,
That opens up a whole new world of possibilities.
If I understand you correctly I would just follow the example of "SEQ_BUTTON_ALL "in the code and duplicate it for the fuctions I want to shift?
I haven't given it a try yet, Im still in build mode. I'm not code savvy so it'll probably be touch and go with this
I've got another question.
Is the 7 segment bpm display, and gate outputs, like those in V3 doable in V2?
-D
