spongebob Posted September 20, 2009 Posted September 20, 2009 I have some strange situation with DIN module. device sends wrong commands.source:void DIN_NotifyToggle(unsigned char pin, unsigned char pin_value) __wparam { // a button has been pressed, send Note at channel 1 MIOS_MIDI_BeginStream(); MIOS_MIDI_TxBufferPut(0x90); // Note at channel 1 MIOS_MIDI_TxBufferPut(pin); // pin number corresponds to note number MIOS_MIDI_TxBufferPut(pin_value ? 0x00 : 0x7f); // buttons are high-active MIOS_MIDI_EndStream(); } reaction on button press:1st SRpins:1: [90 00 7F] Channel 1: Note On C-1 velocity: 127 [90 00 00] Channel 1: Note On C-1 velocity: 02: [90 01 7F] Channel 1: Note On C#-1 velocity: 127 [90 01 00] Channel 1: Note On C#-1 velocity: 03: no reaction4: no reaction5: no reaction6: [b0 4C 3D] Channel 1: CC Sound Controller 7 value: 61 (only on button release)7: no reaction8: no reaction2nd SR - all pins work fine3rd SRpins 1 and 2 - work fine3: [b0 3A 3F] Channel 1: CC LSB 26 (Undefined) value: 63 [b0 3A 41] Channel 1: CC LSB 26 (Undefined) value: 654: [b0 3A 41] Channel 1: CC LSB 26 (Undefined) value: 65 [b0 3A 3F] Channel 1: CC LSB 26 (Undefined) value: 635,6,7,8 - work fine4th SRpins 5,6,7,8 - work finepins 1,2,3,4 only react on button release and send random commands.
spongebob Posted September 20, 2009 Author Posted September 20, 2009 I changed SR with each other, but the result has not changed
spongebob Posted September 21, 2009 Author Posted September 21, 2009 trouble was in application.solved.
