jackchaos Posted November 9, 2009 Report Share Posted November 9, 2009 (edited) I'm using MIOS_AIN_Pin7bitGet() to get an unsigned 7 bit value (0-127) from my pots. Some of the pots need to handle parameters as signed values -63 to +63 where center is 0. I'm able to transmit the correct values over MIDI by: parameter += 0x40; parameter &= 0x7f; However, I'm having trouble displaying the values correctly on the LCD. Positive values are showing up fine, but as I turn into the negative range, the value is displayed as if it were unsigned (because 'parameter' is unsigned). How can I display an unsigned char as a signed 7bit value? Also, the MIOS_LCD_PrintBCD2 functions are not printing leading zeros eg " 6" instead of "06". Can anyone suggest a straight forward way of printing the zero? Regards Edited November 9, 2009 by jackchaos Quote Link to comment Share on other sites More sharing options...
TK. Posted November 9, 2009 Report Share Posted November 9, 2009 ; -------------------------------------------------------------------------- ;; print dec value -64..63 CS_MENU_PRINT_PMDec7 movwf TMP1 movlw ' ' ; space or "-"? btfss TMP1, 6; (if value <= 0x3f (6th bit cleared), print "-" movlw '-' call MIOS_LCD_PrintChar CS_MENU_PRINT_PMDec7_WO_Sign movf TMP1, W ; calc: 0x40-value sublw 0x40 btfsc WREG, 7 ; negate value if negative to get absolute value negf WREG, ACCESS goto MIOS_LCD_PrintBCD2 ; and print it [/code] The same in C: [code] if( value < 64 ) { MIOS_LCD_PrintChar('-'); MIOS_LCD_PrintBCD2(64-value); } else { MIOS_LCD_PrintChar(' '); MIOS_LCD_PrintBCD2(value-64); } The same for MIOS32: MIOS32_LCD_PrintFormattedString("%3d", (int)value - 64); [/code] [code] ; -------------------------------------------------------------------------- ;; print dec value patted with 0 CS_MENU_PRINT_Dec000 clrf MIOS_PARAMETER1 call MIOS_HLP_Dec2BCD movf MIOS_PARAMETER2, W call MIOS_LCD_PrintHex1 movf MIOS_PARAMETER1, W goto MIOS_LCD_PrintHex2 The same in C: MIOS_HLP_Dec2BCD(value); MIOS_LCD_PrintHex1(MIOS_PARAMETER2); MIOS_LCD_PrintHex2(MIOS_PARAMETER1); [/code] The same for MIOS32: [code] MIOS32_LCD_PrintFormattedString("%03d", value); Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
TK. Posted November 9, 2009 Report Share Posted November 9, 2009 P.S.: I added the MIOS32 variant... Quote Link to comment Share on other sites More sharing options...
jackchaos Posted November 9, 2009 Author Report Share Posted November 9, 2009 Thorsten The first example is easily understood and will work perfect for me. I'm a bit lost on the second example, but I'll take your word for it. I'll try it tonite when I get home. Thanks Quote Link to comment Share on other sites More sharing options...
TK. Posted November 9, 2009 Report Share Posted November 9, 2009 I'm a bit lost on the second example, but I'll take your word for it. I'll try it tonite when I get home. The details are explained here: http://www.ucapps.de/cmios8_fun.html#MIOS_HLP_Dec2BCD MIOS_LCD_BCD* uses MIOS_HLP_Dec2BCD internally, and removes the leading zeroes by spaces. If you want to output leading zeroes, just print the original BCD code (binary coded digits, each digit is coded in 4 bits) with MIOS_LCD_PrintHex2 (to print the rightmost binary coded digits) resp. MIOS_LCD_PrintHex1 (to print a single (the leftmost) binary digit) I changed the C example code (removed the bitshifting), so that it matches with the example given in the documentation. Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
