insidius Posted November 30, 2009 Posted November 30, 2009 Hi all, I'm a total n00b building my fist MB6582. Base board has been completed following the instructions very carefully. Followed the testing instructions - everything looking good (had a friend with electronics experience help me with this). Wired up the LCD and it lights up, but nothing is on the screen. Is this normal? What should happen? What do I do now? Please help! Thanks
Syntax Posted November 30, 2009 Posted November 30, 2009 Hi all, I'm a total n00b building my fist MB6582. Base board has been completed following the instructions very carefully. Followed the testing instructions - everything looking good (had a friend with electronics experience help me with this). Wired up the LCD and it lights up, but nothing is on the screen. Is this normal? What should happen? What do I do now? Please help! Thanks Try to adjust the pots/trimmers (P1/P2) on the base panel. They control the amount of contrast of the LCD Kind regards, Frank
clem! Posted November 30, 2009 Posted November 30, 2009 Hi, did you load up the firmware to the pic(s) or any one else? Does the pic send an update request via midi? Best regards, clem!
insidius Posted November 30, 2009 Author Posted November 30, 2009 Try to adjust the pots/trimmers (P1/P2) on the base panel. They control the amount of contrast of the LCD Kind regards, Frank P1/P2??? I'm a bit lost!!!! How do I do this??? Sorry about this but Im a bit confused!
insidius Posted November 30, 2009 Author Posted November 30, 2009 Hi, did you load up the firmware to the pic(s) or any one else? Does the pic send an update request via midi? Best regards, clem! No I did not! What do I do?? I'm stuck. I thought I was going well but I really am a n00b!!! Thanks for the quick replies BTW Much appreciated.
Wilba Posted November 30, 2009 Posted November 30, 2009 P1 and P2 are the contrast and brightness trimmer pots. They are just below the master PIC on the far right. Unless you have just installed MIOS or an application that uses the LCD, you won't see any text on the LCD. Some LCDs will show a row of filled rectangles if they are powered but haven't been initialized by a microcontroller. 99% of the time, people who say "I don't see anything on the LCD" just have the contrast pot turned fully one way, which makes the text invisible. So try that first, as well as turning the brightness to 50%, and uploading something, even a fresh reinstall of MIOS will show "READY." on the LCD.
Syntax Posted November 30, 2009 Posted November 30, 2009 P1/P2??? I'm a bit lost!!!! How do I do this??? Sorry about this but Im a bit confused! These are potentiometers (round black with white inner center) which you can adjust with a small screwdriver. If you don't have uploaded the MIOS firmware to the PIC module yet, there's little to see on the LCD. Look in the MIOS bootloader MIOS8 newbie section (see http://ucapps.de/) how to upload. Kind Regards, Frank
insidius Posted November 30, 2009 Author Posted November 30, 2009 (edited) If you don't have uploaded the MIOS firmware to the PIC module yet, there's little to see on the LCD. Look in the MIOS bootloader MIOS8 newbie section (see http://ucapps.de/) how to upload. Kind Regards, Frank Edited November 30, 2009 by insidius
insidius Posted November 30, 2009 Author Posted November 30, 2009 If you don't have uploaded the MIOS firmware to the PIC module yet, there's little to see on the LCD. Look in the MIOS bootloader MIOS8 newbie section (see http://ucapps.de/) how to upload. Kind Regards, Frank
clem! Posted December 1, 2009 Posted December 1, 2009 (edited) Hi, I have read the nebie section, but still cant understand what I am doing Did you read the right things? http://ucapps.de/mios_bootstrap.html You can read it in french or spanish, too. If language is the prob - try google translation - sometimes funny - but often a little helpful. Best regards, clem! Edited December 1, 2009 by clem!
