highrider Posted January 14, 2010 Posted January 14, 2010 Hi, I'm in my final stages of construction of the MB-6582, onto the CS. Sourcing the mechanical parts in question appears to be a daunting task and extremely expensive (100 spacers for 35 pounds on ebay!!). Can somebody share any advice on sourcing this stuff in the UK,London area? Thanks!
philetaylor Posted January 14, 2010 Posted January 14, 2010 Hi. I tend to use Farnell http://uk.farnell.com/ for lots of this stuff. M3x10mm threaded spacers are about 10p each: http://uk.farnell.com/ettinger/05-03-103/spacer-m3x10-ni/dp/1466761 I had the same experience with this sort of hardware on Ebay.... Cheers Phil
highrider Posted January 14, 2010 Author Posted January 14, 2010 Hi. I tend to use Farnell http://uk.farnell.com/ for lots of this stuff. M3x10mm threaded spacers are about 10p each: http://uk.farnell.com/ettinger/05-03-103/spacer-m3x10-ni/dp/1466761 I had the same experience with this sort of hardware on Ebay.... Cheers Phil Thanks, for the fast reply. This really helped, I have found/ordered almost all of the parts. The only one left is the M3 countersunk head bolt. English is not my first language so I'm a bit challenged in identifying the right components. Could you please confirm if this the right bolt? Other than that I'm done with CS part's sourcing. http://www1.conrad-uk.com Part no.: 521676 - 89 Thanks! Vlad
philetaylor Posted January 14, 2010 Posted January 14, 2010 Hi Vlan. That part looks like a spacer to me (not a bolt/screw!) I can't find any 25mm countersunk bolts/screws on the Conrad site. From Farnell, I have found this: http://uk.farnell.com/tr-fasteners/m325-ksstmcz100/screw-slt-csk-steel-bzp-m3x25/dp/1419379 which is what you are looking for. Thanks Phil
