Probleme sending continuous "CC Effects"
François
My midibox sending such signal continuously, but at the module while AIN is well grounded.
Someone knows where can come the problem?
Thank you in advance to all of you
(sorry for my bad english, goggle traduction is my friends :S)
00000002299732 ms | [b2 5B 03] Channel 3: CC Effects 1 Depth value: 3
00000002299733 ms | [b2 5B 08] Channel 3: CC Effects 1 Depth value: 8
00000002299734 ms | [b5 5B 0A] Channel 6: CC Effects 1 Depth value: 10
00000002299735 ms | [b6 5B 0B] Channel 7: CC Effects 1 Depth value: 11
00000002299736 ms | [b6 5B 02] Channel 7: CC Effects 1 Depth value: 2
00000002299737 ms | [b7 5B 0C] Channel 8: CC Effects 1 Depth value: 12
00000002299738 ms | [b6 5B 01] Channel 7: CC Effects 1 Depth value: 1
00000002299739 ms | [b7 5B 00] Channel 8: CC Effects 1 Depth value: 0
00000002299742 ms | [b6 5B 00] Channel 7: CC Effects 1 Depth value: 0
00000002299750 ms | [b7 5B 01] Channel 8: CC Effects 1 Depth value: 1
00000002299752 ms | [b6 5B 0A] Channel 7: CC Effects 1 Depth value: 10
00000002299753 ms | [b6 5B 02] Channel 7: CC Effects 1 Depth value: 2
00000002299754 ms | [b7 5B 0C] Channel 8: CC Effects 1 Depth value: 12
00000002299755 ms | [b6 5B 01] Channel 7: CC Effects 1 Depth value: 1
00000002299756 ms | [b7 5B 00] Channel 8: CC Effects 1 Depth value: 0
00000002299769 ms | [b6 5B 02] Channel 7: CC Effects 1 Depth value: 2
00000002299770 ms | [b2 5B 04] Channel 3: CC Effects 1 Depth value: 4
00000002299771 ms | [b2 5B 08] Channel 3: CC Effects 1 Depth value: 8
00000002299772 ms | [b5 5B 09] Channel 6: CC Effects 1 Depth value: 9
00000002299773 ms | [b6 5B 09] Channel 7: CC Effects 1 Depth value: 9
00000002299773 ms | [b7 5B 0A] Channel 8: CC Effects 1 Depth value: 10
00000002299774 ms | [b6 5B 02] Channel 7: CC Effects 1 Depth value: 2
00000002299775 ms | [b6 5B 01] Channel 7: CC Effects 1 Depth value: 1
00000002299776 ms | [b7 5B 00] Channel 8: CC Effects 1 Depth value: 0
00000002299788 ms | [b2 5B 04] Channel 3: CC Effects 1 Depth value: 4
00000002299789 ms | [b3 5B 05] Channel 4: CC Effects 1 Depth value: 5
00000002299790 ms | [b3 5B 08] Channel 4: CC Effects 1 Depth value: 8
00000002299791 ms | [b5 5B 0A] Channel 6: CC Effects 1 Depth value: 10
00000002299792 ms | [b6 5B 0A] Channel 7: CC Effects 1 Depth value: 10
00000002299793 ms | [b7 5B 0B] Channel 8: CC Effects 1 Depth value: 11
00000002299794 ms | [b6 5B 02] Channel 7: CC Effects 1 Depth value: 2
00000002299795 ms | [b6 5B 00] Channel 7: CC Effects 1 Depth value: 0
00000002299795 ms | [b7 5B 01] Channel 8: CC Effects 1 Depth value: 1
00000002299806 ms | [b1 5B 02] Channel 2: CC Effects 1 Depth value: 2
00000002299807 ms | [b2 5B 03] Channel 3: CC Effects 1 Depth value: 3
00000002299808 ms | [b3 5B 04] Channel 4: CC Effects 1 Depth value: 4
00000002299809 ms | [b4 5B 06] Channel 5: CC Effects 1 Depth value: 6
00000002299810 ms | [b5 5B 07] Channel 6: CC Effects 1 Depth value: 7
00000002299811 ms | [b6 5B 08] Channel 7: CC Effects 1 Depth value: 8
00000002299812 ms | [b6 5B 02] Channel 7: CC Effects 1 Depth value: 2
00000002299813 ms | [b7 5B 0A] Channel 8: CC Effects 1 Depth value: 10
00000002299814 ms | [b6 5B 01] Channel 7: CC Effects 1 Depth value: 1
00000002299815 ms | [b7 5B 00] Channel 8: CC Effects 1 Depth value: 0
00000002299825 ms | [b4 5B 05] Channel 5: CC Effects 1 Depth value: 5
00000002299826 ms | [b4 5B 06] Channel 5: CC Effects 1 Depth value: 6
00000002299827 ms | [b5 5B 09] Channel 6: CC Effects 1 Depth value: 9
00000002299828 ms | [b6 5B 0A] Channel 7: CC Effects 1 Depth value: 10
00000002299829 ms | [b7 5B 0A] Channel 8: CC Effects 1 Depth value: 10
00000002299830 ms | [b6 5B 02] Channel 7: CC Effects 1 Depth value: 2
00000002299831 ms | [b6 5B 01] Channel 7: CC Effects 1 Depth value: 1
this CC parameter is only sent over eight MIDI channels (B0 5B .. B7 5B)
If you are using the MIDIbox64 application with default configuration, they would be sent by the first eight pots multiplexed by IC1 of the first MBHP_AINX4 module.
Possible errors:
- AIN module not properly powered (check Ground/+5V connections to the 4051)
- pots not properly powered (check Ground/+5V connections at outer terminals)
- the three selection pins of MBHP_AINX4:J6 are not connected to MBHP_CORE:J6
