I was hoping to get a "that will work" from the people in the know.
I have read the MIDI Router pages from TK and want to know if the following setup would work.
-The Core32 module with 8 I/O modules (IIC MIDI)
-On/off switches to isolate specific devices that require Omni for communication.
-I plan to use a LCD during testing, but the final unit will use LEDs for status notifications
From what I have read theoretically 127 of the IIC devices can be used, but it requires a firmware change. If I am planning to use 8 of these, I guess that I would change something in the firmware of the IIC? Or am I misunderstanding and the change is required in the core? Any thoughts on how to implement the switches?
I think that I am comfortable enough to build the parts and pieces, but I want to make sure that I can run 8 devices through the router. I currently have 5 things to connect and there is a possibility of more in future (true for everyone, I am sure).
Thank you all!
  • 2 weeks later...
I was looking at the firmware code for the IIC modules and hope that I found the information about the IIC address.
Code snippets are from the file iic.asm
Original for the first four modules:
;; FUNCTION: IIC_Init_GetAddress
;; DESCRIPTION: initialises the IIC address only - can be called from the
;; mainloop to allow the change on-the-fly without device reset
;; IN: -
;; OUT: -
;; USES: -
IIC_Init_GetAddress
movlw IIC_DEVICE_ADDRESS
btfsc ID0_PORT, ID0_PIN
iorlw 0x02
btfsc ID1_PORT, ID1_PIN
iorlw 0x04
SWITCHBANK_0_1
movwf SSPADD
SWITCHBANK_1_0
return
Modified for additional 4 modules:
;; IN: -
;; OUT: -
;; USES: -
IIC_Init_GetAddress
iorlw 1x02 ;Changed 0 to 1
iorlw 1x04 ;Changed 0 to 1
SWITCHBANK_0_1
movwf SSPADD
SWITCHBANK_1_0
return
Would I be able to update the firmware on the modules without having to flash the PIC?
You only need to change the base address in iic.asm header.
With
IIC_DEVICE_ADDRESS      EQU     0x18
the new device addresses will be 0x18, 0x1a, 0x1c, 0x1e
No, it isn't possible to update the firmware via MIDI or IIC
