Hi
I have interest to build Wilba's sammichSID on standard MB project boards.
Do not find sammichSID CS DOUT map circuit .
SR# 1 6 x CATHODES ,
SR# 2 8 x ANODES I think.
Thanks in advance.
Janis
Edited by Janis1279
You are correct.
Sorry I don't have a schematic publishable at the moment.
It should be easy enough to work out the pin assignments... most tracks are on the top layer.
Just remember that the left side is a MIRROR of the right.
i.e. D0->R1->LED anodes of two MIDDLE columns of three LEDs.
D7->R8->LED anodes of two OUTER columns of three LEDs.
http://midibox.org/forums/index.php?app=gallery&module=images&section=viewimage&img=37
btw if you're interested, I can give you a spare control surface PCB (one of the black prototypes).
Thanks, Wilba !
Left side 3 x 8 diodes :
SR#1 CATHODES rows from UPPER to LOWER D6, D4, D2
SR#2 ANODES from the LEFT to the RIGHT side D7-D0
Right side 3 x 8 diodes :
SR#1 CATHODES rows from UPPER to LOWER D7, D5, D3
SR#2 ANODES from the LEFT to the RIGHT side D0-D7
Regards,
Janis
