findbuddha Posted March 26, 2010 Report Posted March 26, 2010 I just realised I soldered the resistor networks R30-33 direct to the board, instead of using the little sockets. Do they need to be removable? Thanks :) Quote
strophlex Posted March 26, 2010 Report Posted March 26, 2010 I just realised I soldered the resistor networks R30-33 direct to the board, instead of using the little sockets. Do they need to be removable? Thanks :) It depends on what you want to do with the board. I soldered mine too. It is a sequencer and will probobly never change job. I dont't think it is a big problem it you should change your mind anyway, just desolder them or cut them up and desolder them pin by pin and get new ones. Quote
findbuddha Posted March 26, 2010 Author Report Posted March 26, 2010 It depends on what you want to do with the board. I soldered mine too. It is a sequencer and will probobly never change job. I dont't think it is a big problem it you should change your mind anyway, just desolder them or cut them up and desolder them pin by pin and get new ones. Thanks Quote
