protofuse Posted April 2, 2010 Posted April 2, 2010 Hello friends :) as I'm a geek at the same time as a music/sound producer, as soon as my protodeck was OK, I already decided to upgrade it to core32/mios32/firmware 2.0 :D so, I'd need informations about power supply. I'm using actually the little tweak on my 2 core8: http://www.ucapps.de/midibox_lc/midibox_ng_switching_psu.pdf for your information, the modules architecture is described here What should I have to do with my only one core32 ? I have 2 questions: - I'll use the usb only for data. What should I modify for that ? I guess I have to remove the J17 jumper - about the voltage regulator, should I remove it and use the J2 with my external power supply 5V ? All infos would be appreciated :-)
TK. Posted April 2, 2010 Posted April 2, 2010 - I'll use the usb only for data. What should I modify for that ? I guess I have to remove the J17 jumper yes - about the voltage regulator, should I remove it and use the J2 with my external power supply 5V ? Yes, and you don't need to remove the VR if it is already soldered on board. Best Regards, Thorsten.
protofuse Posted April 2, 2010 Author Posted April 2, 2010 hello Thorsten, and thanks for the very fast feedback. I didn't solder anything yet. I began to translate the app for now. only that. I'll upgrade it asap, but I'm involved in many things these days so.... oh, I planned to work on workashops about " making of diy controller for Ableton Live " some people are very interested. it would talk about all the process from the idea/need to ableton live (with all the different worlds crossed ... like midi/osc, max for live and max/msp, Live API and javascript etc) all the best
