Hey guya,
in the last year i had built the midibox fm and since a few month i have been working at the new project. I finally finished a case (which unfortunatelly is too big), the wiring and the rest of the SID. Everything worked on the first run and i can tell everybody to build one. It's nearly easy, you get answer for nearly everything in the forum and when the sid chips are running (was the first issue i had) it is just a little step for a man left .... :)
The other problem i had was based on the connectors i used. The 6.3" female connector has 6 pins and i didn't recognize, that 3 ones are not connected to the male jack when it's plugged in.
Nevertheless ... here are some photos ...
peace,
m
