jordy13 Posted April 18, 2010 Posted April 18, 2010 Hello, I just got my bankstick working and formatted, but when I go to the ensemble menu, or the synth root menu they both lack the SAV function. Ensemble ends with EXT, and the root menu ends with RND. I did a search, and looked through the change logs, but haven't come up with anything thus far. I'm also missing the DET parameter on the OSC menu (it ends with GSA). In all other cases the buttons, and encoder work fine, through the full range. The LCD is a 16x2. Any thoughts would be greatly appreciated :) A little bit at a time this is coming together... Best, Jordan
TK. Posted April 18, 2010 Posted April 18, 2010 Hi Jordan, for a 16x2 LCD the firmware has to be recompiled with "CS_MENU_DISPLAYED_ITEMS" set to 4 in the setup_* file that you are using. Best Regards, Thorsten.
jordy13 Posted April 19, 2010 Author Posted April 19, 2010 Thanks TK! Got it going just fine now. Really makes a difference to be able to save :) Now to add more SID's ..... Best, Jordan
