highpow3rpc Posted May 16, 2010 Report Share Posted May 16, 2010 (edited) Hello all I am building a midibox core32 for traktor I am stuck and would like to ask a couple of questions 1st if I buy the module from smashtv will i have to do any other software/configuration prep work or can i plug the modules straight in plug the usb into the pc and it recognise all the buttons/faders/encoders ? 2nd if it wont parse controls to pc how would I do this (I have no experience coding) Edited May 16, 2010 by highpow3rpc Quote Link to comment Share on other sites More sharing options...
findbuddha Posted May 16, 2010 Report Share Posted May 16, 2010 If you're asking those questions you're going to need to do a lot more reading, both on this forum, the wiki and at ucapps.de The midibox platform (MBHP) runs applications on either a Core8 or Core32 module. Check this page http://ucapps.de/mios32_download.html for a list of released applications for the Core32. Check this page/folder for code/apps and tutorials. The tutorials are good! http://svnmios.midibox.org/listing.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2F This page will explain setting up the toolchain: http://www.midibox.org/dokuwiki/doku.php?id=windows_mios32_toolchain_core Quote Link to comment Share on other sites More sharing options...
highpow3rpc Posted May 16, 2010 Author Report Share Posted May 16, 2010 If you're asking those questions you're going to need to do a lot more reading, both on this forum, the wiki and at ucapps.de The midibox platform (MBHP) runs applications on either a Core8 or Core32 module. Check this page http://ucapps.de/mios32_download.html for a list of released applications for the Core32. Check this page/folder for code/apps and tutorials. The tutorials are good! http://svnmios.midibox.org/listing.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2F This page will explain setting up the toolchain: http://www.midibox.org/dokuwiki/doku.php?id=windows_mios32_toolchain_core Thanks findbuddha for the reply, i have been looking at the examples "MIOS32 C Interface" think its the same as the tutorials page, the system i would like to build will use all 128 of the digital in's (be good if there was slightly more so i could use all encoders and switches instead of pots) and 1 fader for fading between decks, thank you heaps for the links :), and any further help is much appreciated. kind regards Highpow3rpc Quote Link to comment Share on other sites More sharing options...
