mibob Posted June 14, 2010 Posted June 14, 2010 (edited) Hi out there. I want to build my own midicontroller for Ableton. can i use these encoders : http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=300436800357&ssPageName=STRK:MEWAX:IT and these buttons : http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=280508956766&ssPageName=STRK:MEWAX:IT I want to use 16 of this encoders the knobs are for muting , shift , on/off sorry if i didn´t find answer in wiki or forum....looked alot regards Edited June 14, 2010 by mibob
Screaming_Rabbit Posted June 14, 2010 Posted June 14, 2010 Basically I would say, yes you can use the encoders. Though I don't know what "2fach Rechteck" is exactly. About the LED ring, you need to know the matrix constellation. Best for Encoder and Ring: Get the datasheet from the vendor. Switches (these are not knobs): Yes, they should work for you. Greets, Roger
mibob Posted June 14, 2010 Author Posted June 14, 2010 thank you for the very fast reply , i´ll get data sheets... have much to learn , but it´s look like it´s worth the time. greetings i´ll try to get the right terms...
Screaming_Rabbit Posted June 15, 2010 Posted June 15, 2010 i´ll try to get the right terms... No issue... I think you're German, so you have the same problem as me... I also don not always hit the correct term :-) ... and yes, I's worth the time... but be aware of the potential of addiction :shocked: Greets, Roger
