Hi guys,
im using mplab to try compile my project,
but wen i compile the project, i get an error.
here is the cause:
This explanation i found in readme of mplab c18.
Referencing a variable declared 'extern' with an initializer causes an internal failure. For example:
  extern int x = 5;
  void main (void) { x++; }
generates an internal error. The workaround is to remove the 'extern' storage class specification or remove the initializer.
what should i do???
kill me? mysys dont work, mplab dont work... i dont have more ideas.
thanks
Hi guys,
here is the cause:
  extern int x = 5;
what should i do???
thanks
My guess is to follow the suggestion:
1) define the variable in the local module ie:
int x=5;
OR
2) initialise it in the module where it is defined ie. int x=5;
AND declare it (but dont initialise it) where it is used (locally) so your code would be:
extern int x ;
