Hi all,
I am looking for KICAD library files for the ALPS STEC16 and Bourns PEC11 rotary encoders usually used in MIDIbox projects. Has anyone ever used KICAD to build a board that had these encoders?
Thanks, ilmenator
Hi all,
Thanks, ilmenator
Here's my libraries. The PEC11 stuff is converted from the eagle library found in the midibox wiki. I haven't built a board with them, so I can't verify that they're good.
Library.zip
Thanks!
I have created a new set of library files for the encoders in KICAD, also converted from EAGLE. I mainly changed the pin numbers, font size, and the line width so that they better match with the other KICAD libraries.
I have not built a board with these either, which means using the lib is at your own risk :tongue: If someone has the time to create a KICAD parts library page in the WIKI, similar to what exists for EAGLE, feel free to upload this file as well!
Best, ilmenator
encoder.zip
Edited by ilmenator
  • 5 months later...
No, as the project they were intended for never happened :unsure:
As far as I remember, I did not touch any dimension-related aspects of the component after the conversion, just naming convention of the pins. Anyways, the whole thing could be dead wrong or not even intended for PEC11, I don't remember...
  • 8 months later...
