Hi All
I have successfully built the Midimerger using the 16F87x and it is fantastic :D:-)
Thanks Thorsten much appreciated.
I would now like to build the 16F88 version but to cater for 3 in and 1 out.
Can I do this by simply buiding two single versions and cascading them without
having to interface them to each other via an opto-coupler? Would a single
connection with a pull-up resistor do the job? As youv'e probably guessed,
I'm not a designer :wacko:
Any help please?
Thanks
Chris
Hi All
Just to finish this thread.
I built the 16F88 version and cascaded two together thus giving me my required 3 in 1 out. I connected the output of the first 16f88 directly to one of the inputs on the second. Both share the same power source and it appears to work fine. :D As there are only a few components, it fits into a small plastic sandwich box and costs very little compared to a commercial version. So I can happily recommend this.
Cheers
Chris
PS Sorry - seem to have duplicated the original post :unsure:
Edited by nILS
fixed that for ya
  • 4 weeks later...
Hi All
Cheers
Chris
Hi All!
Cas!
What kind of burner and "program" did you use?
I use the MBHP burner with PBrennerNG and the hex file from the http://www.ucapps.de/mbhp_burner.html but I'm failed to burn the code to the 16F88. The burner recognized the chip as a 16F84 :-/
Thx forward!
Cheers!
Hi there!
I just wanted to build the MBHP Merger with PIC16F88.
I build the burner, it's work fine :)
I want to burn the code into the 16F88 and I'm failed.
Are you sure the hex code for the 16F88 is correct?
Because when I burned the code into the PIC, then the PBrennerNG say: it's an 16F84 :( And I can't reprogram the pic :(
In IC-Prog when I load the hex file, the asm list is started like that:
LIST P=16F84, F=INHX8M
include "P16FXX.inc"
ORG 0x0000
BCF PCLATH , 03
BCF PCLATH , 04
Is this correct?
There is anybody who is burned the 16F88 with the MBHP burner & PBrennerNG and the merger (PIC) is work fine?
Thanks for all!
Cheers!
Edited by lipi
