CAS Posted November 27, 2010 Report Posted November 27, 2010 Hi All I have successfully built the Midimerger using the 16F87x and it is fantastic :D:-) Thanks Thorsten much appreciated. I would now like to build the 16F88 version but to cater for 3 in and 1 out. Can I do this by simply buiding two single versions and cascading them without having to interface them to each other via an opto-coupler? Would a single connection with a pull-up resistor do the job? As youv'e probably guessed, I'm not a designer :wacko: Any help please? Thanks Chris Quote
CAS Posted December 10, 2010 Author Report Posted December 10, 2010 (edited) Hi All Just to finish this thread. I built the 16F88 version and cascaded two together thus giving me my required 3 in 1 out. I connected the output of the first 16f88 directly to one of the inputs on the second. Both share the same power source and it appears to work fine. :D As there are only a few components, it fits into a small plastic sandwich box and costs very little compared to a commercial version. So I can happily recommend this. Cheers Chris PS Sorry - seem to have duplicated the original post :unsure: Edited December 12, 2010 by nILS fixed that for ya Quote
lipi Posted January 3, 2011 Report Posted January 3, 2011 Hi All Just to finish this thread. I built the 16F88 version and cascaded two together thus giving me my required 3 in 1 out. I connected the output of the first 16f88 directly to one of the inputs on the second. Both share the same power source and it appears to work fine. :D As there are only a few components, it fits into a small plastic sandwich box and costs very little compared to a commercial version. So I can happily recommend this. Cheers Chris PS Sorry - seem to have duplicated the original post :unsure: Hi All! Cas! What kind of burner and "program" did you use? I use the MBHP burner with PBrennerNG and the hex file from the http://www.ucapps.de/mbhp_burner.html but I'm failed to burn the code to the 16F88. The burner recognized the chip as a 16F84 :-/ Thx forward! Cheers! Quote
lipi Posted January 3, 2011 Report Posted January 3, 2011 (edited) Hi there! I just wanted to build the MBHP Merger with PIC16F88. I build the burner, it's work fine :) I want to burn the code into the 16F88 and I'm failed. Are you sure the hex code for the 16F88 is correct? Because when I burned the code into the PIC, then the PBrennerNG say: it's an 16F84 :( And I can't reprogram the pic :( In IC-Prog when I load the hex file, the asm list is started like that: LIST P=16F84, F=INHX8M include "P16FXX.inc" ORG 0x0000 BCF PCLATH , 03 BCF PCLATH , 04 ..... Is this correct? There is anybody who is burned the 16F88 with the MBHP burner & PBrennerNG and the merger (PIC) is work fine? Thanks for all! Cheers! Edited January 3, 2011 by lipi Quote
lipi Posted January 4, 2011 Report Posted January 4, 2011 So... the problem is solved I hope. Today I programmed my 16F88 with WinPIC. I hope it was succesfully. Quote
