romy Posted December 19, 2010 Posted December 19, 2010 hello everybody, i planned on building a midibox controller my gues is a midibox 64 32 channel faders,a dual main fader 3 turn pots for every channel and 7 buttons for every channel, 1 lcd for every 4 channels a transport section and 30 free assignble buttons im kinda lost in what pcb s i need and how mutch of everything, ald iam wondering if i could use a jog wheel on a 64?? and can i use analog vu meters ?? no motor faders for me it gets to expensive if i do i hope someone is willing to help sorry for my poor english
Flemming Posted December 20, 2010 Posted December 20, 2010 Welcome aboard romy :flowers: As findbuddha points out, you can find all the information you need on www.ucapps.de There you can all read about the Midibox64, but you will also find info on the different modules and their capabilities. You will have to do a lot of reading to find out what is possible, and how it is done. But quickly things will get more clear, and you will find out exactly what you need to build the MIDI controller of your dreams :drool: You can also find a lot of info by browsing and searching the forum. Maybe other people have built boxes that looks like the one you dream about, and maybe you will be inspired too. If you get stuck, you can always ask for help here in the forum.
romy Posted December 21, 2010 Author Posted December 21, 2010 thanks for the reply s, i think i understand it a little better now, iam about to order some kits. for now i have only one question left: can i use analog vu meters for channel metering somehow?
findbuddha Posted December 21, 2010 Posted December 21, 2010 It's not quite clear what you're going to be using your controller for.... is it to control a DAW (similar to a Mackie control: http://www.mackie.com/products/mcupro/)? If so, the Mackie control protocol is probably what you should look at. Try the MBLC project here: http://www.ucapps.de/midibox_lc.html It supports channel metering via LED, and if I recall correctly on the LCD too. It's done via MIDI however, so the latency is too high for most people. I don't know about using analog VU meters.
romy Posted December 21, 2010 Author Posted December 21, 2010 yes, iam going to use it whit sonar. i gues mb lc is the best option for me my plans have changed a little 32 channel faders (motorfaders) rec, mute, solo, pan, for each channel a two main faders, transport buttons, a jog wheel and some more buttons i don t really know yet. lcd for each channel name(1 for every four channels and led display for time/postition but i still cant find out if i can use analog meters for track metering, i love the way it looks but if the delay is to high i might better foget that anyway thanks for the posts
